• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    Member
    Accepted Solution
    transparencies not printing to PDF
    773 Views, 4 Replies
    12-09-2010 08:44 AM
    I did some phasing layout in DR for our scheduling dept. I set transparency at 50% but when I print to pdf the areas and text box transparencies are solid.
    Please use plain text.
    *Expert Elite*
    pendean
    Re: transparencies not printing to PDF
    12-09-2010 10:43 AM in reply to: calvinreinhardt4331
    Which PDF driver?
    Which version of ADR?
    Does it work if you print to a device/printer/plotter?
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Member
    12-09-2010 10:55 AM in reply to: pendean
    I am using DR 2011and Adobe PDF converter, I have acrobat standard 9. I have not printed to paper yet, they are still figuring out the phases
    *Expert Elite*
    pendean
    12-09-2010 02:11 PM in reply to: calvinreinhardt4331
    Test by printing to something else, like a printer or plotter, output to paper: you need to find out if the limitation is your choice of PDF driver.
    Member
    12-10-2010 07:41 AM in reply to: pendean
    Thank you Dean, it does seem to be the PDF driver, the other formats print correctly. We just upgraded to Win 7 so I will have to look into the driver issue.
