• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    layer visability with named views in DWF
    171 Views, 7 Replies
    03-14-2012 12:15 PM
    I would like to have a specific layer visable when a specific named view is active. But I do not want that layer visable on the initial view or when other views are active.
    for example:
    user opens dwf which starts in initial view, user clicks 'named view 1', dwf viewer zooms to view 1 and turns on layer '1'
    user clicks on 'named view 2', dwf viewer zooms to view 2, turns off layer '1' and turns on layer '2'
    user clicks on 'named view 3', dwf viewer zooms to view 3, turns off layer '2' and turns on layer '3'... and so on...
    is this possible?
    thanks in advance.
    Please use plain text.
    Re: layer visability with named views in DWF
    03-19-2012 08:33 AM in reply to: jfhenry
    anybody???
    Active Contributor
    vgottipa
    03-22-2012 03:03 PM in reply to: jfhenry
    I am not sure if you are asking this from the API perspective, if you have your own application with ADR control integrated into it, I think the functionality you are looking for is easily acheivable. However, I am not sure if you could do this by using ADR off the shelf.
    03-22-2012 04:29 PM in reply to: jfhenry
    Well I don't have an app yet, but I'm thinking about building one with this funtionality. Any ideas or examples of code to accomplish this? Thanks.
    Employee
    03-23-2012 02:14 AM in reply to: jfhenry
    Thank you for your question.
    You can embed an ADR ActiveX control in VB.NET, VC.NET, and JavaScript, and use the APIs to customized it. You can refer to ADR API Documentation.
    You can leverage PageView & PageLayer to implement your application.
    Please let me know if you have any further question.
    Herbert He
    SW Engineer
    PSEB-GE- ACRD PSEB
    03-23-2012 05:54 AM in reply to: jfhenry
    thank you for your help.
    btw, do you have any consultants that you can recommend to assist us in building a web application to implement this functionality?
    thanks again.
    03-26-2012 07:54 AM in reply to: jfhenry
    anybody?? recommendation on a consultant?
    Active Member
    03-26-2012 05:18 PM in reply to: jfhenry
    Please reach me at swiftbim@gmail.com. Thanks.
