• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    Distinguished Mentor
    ampster
    image not visible in dwfx file
    1507 Views, 12 Replies
    09-11-2012 07:58 AM
    Design Review 2013 used to view dwfx exported out of Inventor 2011 part file with jpg image inserted into sketch.
    Does Design Review have the capability of showing images inserted into sketches of Inventor part files?
    I see it has the ability to open multiple image file formats, but find it odd it won't display images within part files.
    The search function of this forum, as usual isn't very productive.
    Please use plain text.
    ampster
    Re: image not visible in dwfx file
    09-12-2012 05:42 AM in reply to: ampster
    tried this with AutoCAD 2011 also.  Inserted jpg file into dwg and exported out as dwfx.
    Only the image border shows up in Design Review 2013.
    pendean
    09-12-2012 05:46 AM in reply to: ampster
    Your are describing an output problem (the programs are not creating the image), as opposed to a viewing problem.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    ampster
    09-12-2012 07:42 AM in reply to: pendean
    to tell you the truth Dean, I don't know if it's AutoCAD/Inventor's problem (output) or if it's a limitation of Design Review to "see" or show image files placed into dwg/ipt files that are exported out to dwfx!
    What little search results I get from searching the forum here, I get the impression that Design Review should be showing image files that are placed into dwg files and then exported out to dwf/dwfx files.
    I've tried jpg files in both Acad dwg and Inv. ipt files as well as bmp files in ipt files.  I'll go test a bmp in a dwg and see what happens.
    ampster
    09-12-2012 07:56 AM in reply to: ampster
    bmp's don't show up either.
    simple workflow but here it is
    1.  Start new dwg file from acad.dwt template in Acad 2011.  Saved as Drawing2.dwg
    2.  Insert > Raster Image Reference > browse to and select "yosemite_sam2.bmp" image file
    3.  Save dwg file.
    4.  File > Export > Files of Type set to "3D DWFx" and save as Drawing2.dwfx
    Open the dwfx file in Design Review 2013 and all I see is the image border.
    Yesterday I did use the ""Bring to Front" and "Bring Above Objects" commands in Acad attempting to adjust the draw order - although with nothing else in the file I didn't expect these commands to have any effect and they didn't.
    I get the impression that "something" needs to be done to the image file in either Acad or Inventor in order for Design Review to actually be able to display the image file.
    I can attach the files used if needed, but there's nothing complicated or different about them (jpg, bmp, dwg, ipt & dwxf).
    Am I wasting my time attempting to get this to work?
    pendean
    09-12-2012 08:45 AM in reply to: ampster
    Post an image and I can try it here with AutoCAD.
    ampster
    09-12-2012 10:04 AM in reply to: pendean
    jpg and bmp
    If you couldn't tell, ultimately this will be used for a mudflap on the single wheel trailer I made last winter.
    I've already created the model in Inventor and have the image inserted into that part file.  I'd just like the dwfx files to show the image.
    Thanks for testing this in Acad Dean.
    pendean
    09-12-2012 01:06 PM in reply to: ampster
    AutoCAD would not attach your JPG but the BMP worked, and I added one of my own. Test and review.
    ampster
    09-12-2012 01:39 PM in reply to: pendean
    Thanks again for testing!
    Both the dwf and dwxf you supplied display both images files.
    I opened the dwg you created, apparently in Civil3D going by the proxy notices I received.  The yosemite sam bmp displays (apparently wasn't linked to the dwg) but the Texas image did not display (linked I assume and would need to be sent with the dwg - no problem).
    Now when I attempt to export out of the dwg you supplied Dean, the dwf file it created does not display the yosemite sam image, but does display the two image boundaries?!?!
    What did you do different?
    To recap, I'm using plain AutoCAD 2011 and viewing the dwf/dwfx files in Design Review 2013.
    pendean
    09-13-2012 05:29 AM in reply to: ampster
    Plain AutoCAD 2012 here, nothing special, used the REF palette to attach the images then simply used PLOT to the default PC3 files for DWF and DWFx.
    Don't have access to Civil3D here.
