• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    Member
    exporting from a CAD program to a DWF file
    236 Views, 5 Replies
    08-05-2012 09:04 AM
    When exporting to a ASCII or Binary DWF, file the file appears as all white on the Autodesk Design Review viewing screen rather than the entity colors from the .dwg file.  How do I correct this?
    Please use plain text.
    *Expert Elite*
    pendean
    Re: exporting from a CAD program to a DWF file
    08-06-2012 05:50 AM in reply to: mellis786
    Please define "exporting" and from which CAD program... .
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Member
    08-06-2012 05:55 AM in reply to: pendean
    Exporting means saving a .dwg file in some other format, such as .dwf or .pdf. I am using Bricscad version 12
    *Expert Elite*
    pendean
    08-06-2012 06:13 AM in reply to: mellis786
    So you are asking about creating a DWF from BRICSCAD, made by someone other than Autodesk? How do you know it creates colored binary DWF files? Are you sure there is no setting in the program to turn colors on and off? YOu can do so in AutoCAD for example using plot style tables... .
    How would asking over here (the viewer) fix a problem that may already reside in the DWF? Just curious.
    Can you share the DWF?
    Member
    08-06-2012 07:20 AM in reply to: pendean
    thanks. changing the plot style settings cleared up the problem
    *Expert Elite*
    pendean
    08-06-2012 11:33 AM in reply to: mellis786
    Glad it was a simple fix.
