• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Design Review
    Member
    Zoom the object in 3D
    338 Views, 2 Replies
    08-31-2009 01:06 AM
    What zoom the object in 3D, knowing his coordinates.
    From sample:
    '//Object extents - use these to zoom into all objects in the user collection.
    MyObjectsNamedCollection.Flush()
    MyObjectsNamedCollection.AddNamedItem(TempObject, "TempObject")
    ObjectContent2.Objects(1) = MyObjectsNamedCollection
    If Section.Href.Contains("eModel") Then
    cObjectExtents = CType(ObjectContent2.Extents(MyObjectsNamedCollection), AdCommon.IAdCube)
    end if
    What use cObjectExtents?
    Please use plain text.
    Employee
    Re: Zoom the object in 3D
    09-08-2009 07:38 PM in reply to: _Sari
    Thank you for your question.
    cObjectExtents is an 'IAdCube' object which is similar with IAdRect object in 2D, from which you can retrieve the bounding box of one object.
    You can fill the 'EModelSection.Camera' with this bounding box if you want to zoom an object in 3D.
    Please let me know if this suggestion is helpful or if you have any follow-on questions.
    -Tank
    Tank
    SW Engineer
    PSEB-GE-ACRD-CPG
    Autodesk, Inc.
    Member
    09-10-2009 05:25 AM in reply to: _Sari
    Prompt please, what assign the coordinates of the camera knowing cObjectExtents.Top, cObjectExtents.Left, cObjectExtents.Right, cObjectExtents.Bottom, cObjectExtents.Back, cObjectExtents.Front object?
    I can not understand, as on this coordinate to install the camera in necessary position?
    Shall very grateful.
    Edited by: _Sari on Sep 10, 2009 12:26 PM Edited by: _Sari on Sep 10, 2009 12:30 PM
