• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    New Member
    Transparency of colours not printing out
    524 Views, 7 Replies
    06-01-2006 07:52 AM
    Fill colours that are set to transparent in the DWF drawing, do not print out as transparent in the hard copy or in a PDF copy. They print as solid colour therefore obscuring the drawing below. Is there a way that the transparent fill colours can print out as they appear on the DWF drawing?
    Please use plain text.
    *Scott Sheppard [Autodesk]
    Re: Transparency of colours not printing out
    06-01-2006 09:31 AM in reply to: h.leonard
    Please send me the DWF. Transparent colors are supposed to print as they
    appear on the screen. If you could also send the source file, that helps tie
    break between the DWF Viewer and the application that published the DWF.
    wrote in message news:5192184@discussion.autodesk.com...
    Member
    07-03-2006 05:02 AM in reply to: h.leonard
    Thanks for the reply.
    I am not sure if you require the original DWG file, if so, can you let me know.
    For now, I attach the DWF of a drawing, then the same drawing with transparent colours added and finally a PDF to show how this drawing prints out.
    Hugh
    Member
    07-03-2006 05:05 AM in reply to: h.leonard
    DWF file with transparent fill colours
    Member
    07-03-2006 05:07 AM in reply to: h.leonard
    PDF of the DWF file to show how it prints out
    07-05-2006 09:55 AM in reply to: h.leonard
    I was able to print the DWF with proper transparency on my HP device. I used
    Autodesk Design Review 2007. I have attached a scan of my printout. You can
    see the red text and other objects behind the transparent areas.
    wrote in message news:5225547@discussion.autodesk.com...
    know.
    out.
    Hugh
    New Member
    s1newman
    08-03-2011 10:43 AM in reply to: *Scott Sheppard [Autodesk]
    I am using ADR 2012, and have very similar problem as discussed above. Although I can print out the fill colour as transparent in hard copy, it will present as solid colour when I PDF the drawing.
    Please advise.
    Employee
    08-04-2011 11:20 PM in reply to: s1newman
    Could you please attach a test file to this thread for deep investigation?
    Ben Wu
    SW Engineer
    PSEB-GE-ACRD
