• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    New Member
    Re: "There was a problem displaying the file"
    08-20-2009 09:12 AM in reply to: noahma
    I experienced this same issue when exporting files that were created in ShipConstructor 2008. A work around I've found is to explode the blocks, or referenced files, I tend to remove all the lines and polylines as well, although this might not be necessary. Good luck.
    Please use plain text.
    Active Contributor
    08-27-2009 12:40 AM in reply to: noahma
    Anybody found a solution for this problem?
    it is becomming really annoying not to be able to create a 3DDWF with realistic materials etc.
    TIA
    Wouter
    Active Contributor
    11-04-2009 01:12 AM in reply to: noahma
    Well,
    I have been searching for a solution.... and i found a workaround.
    If i create a section-line next to the model and set it up so it goes trough the entire model (so it actually does not create a section) and set the section-line to 'live section', i can export the model to a 3D-dwf and open it in DesignReview without problem's
    Hope this help's others with the same problem...
    Distinguished Contributor uma
    01-21-2013 08:11 AM in reply to: wouterbleumink
    Just got this error on attempt to open in Design Review 2013 Unverferth Bearing Maintanance.ipb (from the sample projects pack) exported to DWF with Inventor Publisher 2013 SP3.
    02-15-2013 06:34 AM in reply to: uma
    Nevermind - I can't reproduce the issue from the other PC
