• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    Member
    Save DWF Markup back to webserver
    84 Views, 4 Replies
    04-05-2006 02:30 AM
    Hi All,
    I think the question has been asked before, but I could not find an answer, so I'll post it again.
    I am working on an implementation of DWF Composer for a client. What I want to do is enable a customer of my client to markup the drawings my client creates, to speed up the workflow. Since their offices are quite far apart, we want to use the Internet, and so I am putting the DWF files on a webserver and wrote a website around it. The client surfs to this website, looks at the drawings, adds markup if necessary, and here is where the tricky bit comes in: It looks like DWF composer will not allow the client to save the marked DWF back to the webserver. Is there a way to do that? Or does the customer have to save as to local disk, then upload the file to the webserver again? That would be a rather clumsy approach, if you ask me. Composer should be able to see that the DWF is coming from http://www.server.nl/drawings, and try to save it back to that URL in my opinion. The documentation suggests as much:
    It says somewhere that embedding the Composer in your website allows the customer to markup and view drawings without having to download them! Which is why I reccommended Composer to my client ...
    Was I wrong in recommending Composer? I certainly hope not.
    TIA,
    Stefan
    Please use plain text.
    *Scott Sheppard [Autodesk]
    Re: Save DWF Markup back to webserver
    04-05-2006 06:24 AM in reply to: StefJager
    Someone from the viewer development team can correct me if I am wrong, but
    the way I understood is that both the Autodesk DWF Viewer and Autodesk DWF
    Composer operate on local copies. When you view a DWF file from a web site,
    a copy of the DWF file is downloaded to your computer. That local copy is
    then loaded. When you save a DWF, the file is saved locally and then
    uploaded back to the server. I am thinking of how the viewers integrate with
    Buzzsaw. On the other hand, DWF files do stream in that some of the geometry
    starts to be displayed before the entire file has been downloaded, so I am
    not sure.
    wrote in message news:5132431@discussion.autodesk.com...
    Hi All,
    TIA,
    Stefan
    Member
    04-06-2006 07:36 AM in reply to: StefJager
    Scott,
    The fact that they work on local copies is not what bothers me. As a matter of fact, that is how browsers work (Temporary Internet Files: You can find anything you've visited there). What bothers me is that it is not very user-friendly, because now I have to write an upload-function in my website, the user has to markup de DWF, save it to his/her local disk, then upload it back to the server. If Composer would simply save the DWF back to the server, it's much easier for the user. How it works under the hood (that there always ia and always will be a local copy) should remain hidden from the user. And checking out the DWF Viewer code, it IS streaming the DWF's in so streaming in or out with a URL as source/destination shouldn't be that hard.
    Stefan
    *Ben Cochran
    04-10-2006 10:26 AM in reply to: StefJager
    You are right; saving to a web server is very doable. This would be a good
    feature for a future release. I will forward your request on to the product
    manager.
    Ben Cochran
    wrote in message news:5134324@discussion.autodesk.com...
    Scott,
    hard.
    Stefan
    Member
    04-11-2006 01:23 PM in reply to: StefJager
    Ben,
    Thanks, if it's added it would be a big help. Not now unfortunately, I know how it works with big software companies (worked for one myself - now I am a small one myself ;-) ), it will take some time, but I've designed a website around it that they will find serviceable (I hope). Later on I expect that the functionality will come in really handy.
    Stefan
    PS. Composer's Helpfile is ahead of you:
    "Embedding a DWF file into a Web site allows your customers to
    quickly access a drawing for review, without downloading it." straight copy-and-paste!
