Autodesk Design Review
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
*Quinn Zander
Printed Image is Mirrored
Options
- Highlight
- Email to a Friend
100 Views, 4 Replies
07-26-2004 11:45 PM
Is this a known issue?
I have a DWF that was created from inserting a Jpeg with some added
markups.
The Jpeg is simply a captured table of text.
Printing this DWF causes the image to be completely mirrored (to see the
text, you must hold the page up against a light source and read
"through" the paper).
Very Strange.
QBZ
*Quinn Zander
Re: Printed Image is Mirrored
Options
- Highlight
- Email to a Friend
07-26-2004 11:49 PM in reply to:
*Quinn Zander
I just noticed that the markups are coming through right-side-up, but,
the image (from Jpeg) is both upside-down and mirrored.
QBZ
"Quinn Zander" wrote in message
news:4105fa3f_3@newsprd01...
> markups.
the
> Very Strange.
> QBZ
*Susan Scott [Autodesk]
Options
- Highlight
- Email to a Friend
08-02-2004 08:59 AM in reply to:
*Quinn Zander
Quinn -
I have not heard of this problem before. Can you send your DWF to me and
the other DWF Composer developers so that we can investigate this problem?
And also tell us:
1. printer model
2. OS
thanks,
Susan Scott
Autodesk Viewers QA
news:4105fb19_2@newsprd01...
> QBZ
> > markups.
> the
> > Very Strange.
> > QBZ
Options
- Highlight
- Email to a Friend
08-03-2004 12:06 PM in reply to:
*Quinn Zander
Hi Quinn,
I've been looking into the print issue you reported and so far have not been able to reproduce the image mirroring problem that you are seeing. I don't have access to an HP DeskJet 6122, but I have successfully printed the file to an HP DeskJet 1220C, an HP Business InkJet 2230, and to an HP LaserJet 9000 PCL6 with no problems noted. In all cases I used the default Print settings (Full Page, Letter, Landscape, Best Fit). Is there anything unique about the Printer configuration that you are using? (For example, under Properties for the HP DeskJet 6122, are there any custom features that are turned on? My DeskJet 1220C has a 'Mirror Image' feature that is off by default but which can be configured.)
Thanks in advance for any additional information you can provide.
-- Scott Lillibridge, Autodesk Viewers QA
*Quinn Zander
Options
- Highlight
- Email to a Friend
08-03-2004 12:26 PM in reply to:
*Quinn Zander
Scott,
I have also discovered that I do indeed have a "mirror image" checkbox
that DOES allow the image DWF to print properly, but it will also print
"normal"( Published IDW's from IV) DWF's mirrored.
I suppose I could print seperate "image" pages with the mirror function
on, then switch it off and print the drawing sheets independantly.
I will try printing with several different machines in the next couple
of days and see if I find any other mirrored prints.
At least it seems to be local to my setup. Without this wonderful
(fast/easy) way of collaborating (marking up images-genius functionality
by the way!!) I was starting to get the "half-baked" feeling about
Composer.
I will continue to use this functionality but make sure recipients are
aware that if they are lucky enough, they might be able to produce a
mirrored print.
Thanks for looking into this for me.
QBZ
"SLillibridge (ADSK)" wrote in message
news:14943034.1091560030760.JavaMail.jive@jiveforu m2.autodesk.com...
> Hi Quinn,
