Autodesk Design Review
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Hyperlinks Problem - ADR 2013
- Highlight
- Email to a Friend
I downloaded and installed the latest version of ADR(2013). I see that that hyperlinks from old files, generated with relative paths from Autocad, do not work any more. They used to work fine with ADR 2012.
It seems to me that the new ADR does not read the relative paths correctly and appends the relative path to the directory address of the original file.
Does anyone else experience this behaviour?
Re: Hyperlinks Problem - ADR 2013
- Highlight
- Email to a Friend
Thank you for reporting this issue.
Please provide the dwf/x file for us to reproduce the issue and investigate it.
Thanks.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
- Highlight
- Email to a Friend
I may not be able to upload a document in the forum. Is there an email or ft site that I can use?
- Highlight
- Email to a Friend
Thank you for your feedback.
The FTP server ftp://files.autodesk.com:
LoginID : simulation
Password: ADR2009CST
Please let me know the file name once you uploaded it.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
- Highlight
- Email to a Friend
The ftp login information you provided does not work for some reason.
- Highlight
- Email to a Friend
I'll check it. You can send the file to me directly.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
- Highlight
- Email to a Friend
Hi vgottipa,
It's a regression from ADR 2012. I logged this defect in our database (ADRPO-1414) and we will consider fixing it in future releases.
Any further question please let me know.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
- Highlight
- Email to a Friend
Relative paths not working / failing in Autodesk 2013 Design Review is not a small issue. Autodesk Design Review has been a fantastic product that has allowed us to introduce AutoCAD to our clients and recommend AutoCAD as a design platform for many clients who are otherwise indifferent. We have encouraged multiple clients to use Design Review to access information information we provide on their projects and we use AutoCAD to produce these documents. The packages we provide are completely dependant on relative paths working correctly in Autodesk Design Review.
The markup capability of Design Review trumped Bentley View when deciding which program to to recommend our clients choose for this package (AutoCAD or Microstation). Hyperlinks failing when using relative paths completely sinks Design Review / AutoCAD for the purposes outlined above. It simply will not work. We are currently forced to inform all of our existing AutoCAD based clients of the defect and direct them to an old release or suggest a Bentley View / Microstation platform. Our clients love the markup capability of Autodesk Design Review and we would prefer to recommend it for that reason.
Again, this is not a small issue. Please let us know if Autodesk intends to resolve this issue and if so, when we can expect it to be repaired if it has not already been corrected.
Lane Sater
- Highlight
- Email to a Friend
This is a huge problem for our company also. Our entire library was dependent on these hyperlinks for navigation amongst files, and it has become a very slow process with ADR 2013. I had hoped to uninstall ADR2013 and reinstall ADR2012, but apparently that is no longer available either. If you cannot fix it, please give access to ADR2012. This is a very big problem and should be fixed prior to any future releases........PLEASE!!
Brian Davidson
- Highlight
- Email to a Friend
My company also relies on dwf's with embedded hyperlinks. A hotfix should be provided asap. Thanks!
Sincerely,
Scott Salas
