• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    Active Contributor
    vgottipa
    Hyperlinks Problem - ADR 2013
    1199 Views, 13 Replies
    03-29-2012 12:09 PM
    I downloaded and installed the latest version of ADR(2013). I see that that hyperlinks from old files, generated with relative paths from Autocad, do not work any more. They used to work fine with ADR 2012.
    It seems to me that the new ADR does not read the relative paths correctly and appends the relative path to the directory address of the original file.
    Does anyone else experience this behaviour?
    Please use plain text.
    Employee
    Re: Hyperlinks Problem - ADR 2013
    04-01-2012 01:22 AM in reply to: vgottipa
    Thank you for reporting this issue.
    Please provide the dwf/x file for us to reproduce the issue and investigate it.
    Thanks.
    Herbert He
    SW Engineer
    PSEB-GE- ACRD PSEB
    Autodesk, Inc.
    Active Contributor
    vgottipa
    04-02-2012 04:26 AM in reply to: herbert.he
    I may not be able to upload a document in the forum. Is there an email or ft site that I can use?
    Employee
    04-04-2012 06:22 PM in reply to: vgottipa
    Thank you for your feedback.
    The FTP server ftp://files.autodesk.com:
        LoginID : simulation
        Password: ADR2009CST
    Please let me know the file name once you uploaded it.
    Herbert He
    SW Engineer
    PSEB-GE- ACRD PSEB
    Autodesk, Inc.
    Active Contributor
    vgottipa
    04-05-2012 07:25 AM in reply to: herbert.he
    The ftp login information you provided does not work for some reason.
    Employee
    04-05-2012 06:33 PM in reply to: vgottipa
    I'll check it. You can send the file to me directly.
    Herbert He
    SW Engineer
    PSEB-GE- ACRD PSEB
    Autodesk, Inc.
    Employee
    04-08-2012 11:07 PM in reply to: herbert.he
    Hi vgottipa,
    It's a regression from ADR 2012. I logged this defect in our database (ADRPO-1414) and we will consider fixing it in future releases.
    Any further question please let me know.
    Herbert He
    SW Engineer
    PSEB-GE- ACRD PSEB
    Autodesk, Inc.
    Member
    04-19-2012 12:21 PM in reply to: vgottipa
    Relative paths not working / failing in Autodesk 2013 Design Review is not a small issue.  Autodesk Design Review has been a fantastic product that has allowed us to introduce AutoCAD to our clients and recommend AutoCAD as a design platform for many clients who are otherwise indifferent.  We have encouraged multiple clients to use Design Review to access information information we provide on their projects and we use AutoCAD to produce these documents.  The packages we provide are completely dependant on relative paths working correctly in Autodesk Design Review.
    The markup capability of Design Review trumped Bentley View when deciding which program to to recommend our clients choose for this package (AutoCAD or Microstation).  Hyperlinks failing when using relative paths completely sinks Design Review / AutoCAD for the purposes outlined above.  It simply will not work.  We are currently forced to inform all of our existing AutoCAD based clients of the defect and direct them to an old release or suggest a Bentley View / Microstation platform.  Our clients love the markup capability of Autodesk Design Review and we would prefer to recommend it for that reason.
    Again, this is not a small issue.  Please let us know if Autodesk intends to resolve this issue and if so, when we can expect it to be repaired if it has not already been corrected.
    Lane Sater
    Member
    05-03-2012 08:54 AM in reply to: vgottipa
    This is a huge problem for our company also. Our entire library was dependent on these hyperlinks for navigation amongst files, and it has become a very slow process with ADR 2013.  I had hoped to uninstall ADR2013 and reinstall ADR2012, but apparently that is no longer available either.  If  you cannot fix it, please give access to ADR2012.  This is a very big problem and should be fixed prior to any future releases........PLEASE!!
    Brian Davidson
    Active Contributor
    05-11-2012 10:26 AM in reply to: vgottipa
    My company also relies on dwf's with embedded hyperlinks.  A hotfix should be provided asap.  Thanks!
    Sincerely,
    Scott Salas
