• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    Active Member
    How to programmatically select objects
    422 Views, 2 Replies
    08-13-2012 02:59 AM
    Hi!
    Can't figure out how to programmatically select a group of objects in a ECompositeViewer so they will be highlighted somehow? Or maybe i can somehow colorize them just how TRANSPARENT command works?
    Please use plain text.
    Active Member
    Re: How to programmatically select objects
    09-20-2012 05:22 AM in reply to: sinm
    I would like to know how to do this too. Any suggestions autodesk admins?
    I think it would also be very useful to get all the code examples that are embedded within the windows .chm help file up on a web page somewhere. Copying code out of the windows help viewer is a right pain and loses all formatting.
    Cheers
    Active Member
    09-20-2012 06:21 AM in reply to: troup
    I got this working in javascript with help from the following article:
    http://dwf.blogs.com/beyond_the_paper/dwf_programming/page/2/
    You can also control the selection set programmatically. First call IAdContent::CreateUserCollection to return an empty IAdUserCollection. You can then add to it the IAdObject interfaces of those objects you want selected. Once complete, you can “set” the IAdContent::smileysurprised:bjects(ObjectType::smileyfrustrated:elected) property to your collection to effect the desired selection."
    I translated this to the following Javascript:
    var MyCollection = ECompViewer.Section.Content.CreateUserCollection();
    MyCollection.AddItem(objectYouWantToSelect);
    ECompViewer.Section.Content.Objects(1) = UserCollection;
    //Replace objectYouWantToSelect with a reference to your object
    //The API uses Magic numbers 1 = selected
