• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    New Member
    MikeCompton
    How Can You Silently Uninstall ADR?
    547 Views, 2 Replies
    11-21-2011 05:00 AM
    I need to be able to uninstall ADR 2012 from a command line silently.
    In this instance it is 2012, but i expect the command line switches are same/similar for older versions.  The uninstall string is
    C:\Program Files\Autodesk\Autodesk Design Review 2012\Setup\Setup.exe /P {9E4D5A41-1051-4F1A-8342-ECB26CA0C86C} /M ADR /language en-US
    But that is not silent.
    Please use plain text.
    Employee
    Re: How Can You Silently Uninstall ADR?
    11-22-2011 06:42 PM in reply to: MikeCompton
    Please try the command
    msiexec /uninstall {9E4D5A41-1051-4F1A-8342-ECB26CA0C86C} /quiet
    However,  it haven't been tested.
    Ben Wu
    SW Engineer
    PSEB-GE-ACRD
    New Member
    MikeCompton
    11-23-2011 02:30 AM in reply to: wube
    Thanks, much appreciated.
    I think i did try that SID but the desktop icon didnt disappear so i assumed it hadnt worked.  A reboot later and further testing confirms the above command works fine, although i have actually setup our package to use:
    msiexec /x {9E4D5A41-1051-4F1A-8342-ECB26CA0C86C} /norestart /passive
    So if run manually, the technician can see the progress and when run programatically, its hidden from the user anyway, as it runs with the SYSTEM account.
    Thanks for your reply.
