• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Design Review
    Active Contributor
    vgottipa
    Fidelity Setting
    104 Views, 3 Replies
    04-11-2012 09:23 AM
    Does anyone know if it is possible to set fidelity value from the API. Thank You.
    Please use plain text.
    Employee
    Re: Fidelity Setting
    04-11-2012 07:02 PM in reply to: vgottipa
    Thank you for your question.
    Its value can not be set from ADR API.
    However, this value was recorded in the windows registry. So it's still possible for you to set this value programmatically. The DWORD value "Fidelity" locates in:
        HKEY_CURRENT_USER\Software\AppDataLow\Software\Au​todesk\Design Review\Preferences\User Interface
    or
        HKEY_CURRENT_USER\Software\Autodesk\Design Review\Preferences\User Interface
    Any further question please let me know.
    Herbert He
    SW Engineer
    PSEB-GE- ACRD PSEB
    Autodesk, Inc.
    Active Contributor
    vgottipa
    04-12-2012 07:06 AM in reply to: vgottipa
    Thanks much for pointing me to registry values. There are a host of other properties I would like to use there.
    Active Contributor
    vgottipa
    04-12-2012 07:40 AM in reply to: herbert.he
    I am successfully able to change the setting in the registry. However when the ActiveX control loads it is not using the new registry value. Do you know why this may be happening. Thanks again for your help.
    Dim regPath As String = "HKEY_CURRENT_USER\Software\AppDataLow\Software\Autodesk\Design Review\Preferences\User Interface"
    Dim fidelityVal As String = ""
    Try
    fidelityVal = Registry.GetValue(regPath, "Fidelity", "_NONE")
    Catch ex As Exception
    logFile.WriteLine(ex.Message)
    End Try
    If fidelityVal = "_NONE" Or fidelityVal = "" Then
    regPath = "HKEY_CURRENT_USER\Software\Autodesk\Design Review\Preferences\User Interface"
    Try
    End Try
    End If
    If Not fidelityVal = "_NONE" And Not fidelityVal = "" Then
    Try
    Registry.SetValue(regPath, "Fidelity", "20")
    End Try
    End If
