• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    Member
    Exception embeeding Autodesk Design Review 2013 in VS2010 C#
    820 Views, 3 Replies
    05-04-2012 01:13 AM
    I'm working on a Ms Vista x64 system...
    I've created a new WinForm C# application (NET framework 4.0 - any cpu).
    I've added in Visual studio 2010 toolbox the Autodesk DWF Viewer Control (file located in Program Files\Common Files\Autodesk Shared\DWF Shared\AdView.dll) .
    When i drop the control from the toolbar in to a WinForm, Visual Studio hangs with an exception (exc eption code
    e0434352). How should I proceed?
    Please use plain text.
    Member
    Re: Exception embeeding Autodesk Design Review 2013 in VS2010 C#
    10-09-2012 08:00 AM in reply to: DGProgrammer
    I am facing with the same problem. Did you solved this problem yet? Can you advise me about and please where to find
    dwg file open method in API. How to open dwg file with API in C#?
    regards, Vojko
    Member
    10-10-2012 02:56 AM in reply to: vzavec
    Sorry, no solution found. Regards, Diego.
    Member
    10-22-2012 09:50 PM in reply to: DGProgrammer
    Try to add that again and again, finally you'll  succeed.
    But that's not the end of story. When you compile, VS will crash too.
    Luckly you compile successfully, it crashes as soon as you debug.
    So ,what you need is more patience Or  VS2008
