• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    Active Member
    Error when publishing DWF to 'overwrite' an existing file
    633 Views, 13 Replies
    08-13-2009 05:39 AM
    Hello, when I go to an existing DWF file and try to overwrite it from autocad 2010 it says 'file is currently open in another program. Please close the file and try again.' I can do this in cad 2008. Any idea's? Thanks
    Please use plain text.
    Product Support
    Re: Error when publishing DWF to 'overwrite' an existing file
    08-21-2009 06:28 AM in reply to: captain74
    What process are you using to complete the task? I have tested this fully and the functionality still works in AutoCAD 2010. The only way I was not able to overwrite the existing DWF is if in actuality it was open. Please confirm that the DWF is not already open, and if the problem persists, let us know the steps you are using to try and accomplish this.
    Shawn Niles
    Autodesk Product Support
    Shawn Niles
    Product Support Team Lead
    Product Support
    Autodesk, Inc.
    Employee
    08-24-2009 09:29 PM in reply to: captain74
    Thank you for your question.
    Autodesk fixed an error where the DWF was erroneously being overwritten by AutoCAD, so it sounds like you are running into that workflow.
    And your problem sounds similar to another issue posted, for correct workflow, please refer to Kevin’s suggestion in this link: http://discussion.autodesk.com/forums/thread.jspa?threadID=741153&tstart=0
    Please let me know if I can be of any further help.
    Dony
    Active Member
    08-25-2009 05:17 AM in reply to: captain74
    Here is my DWF print procedure.
    1-Click Publish
    2-Load List of Sheets (.dsd)
    3-Publish DWF
    4-Go to DWF file I want to overwrite
    5-Choose and click Save
    6-Get ....Error when publishing DWF to 'overwrite' an existing file...
    Other Points:
    We are on a server where we save eveything
    NO one else has it open
    AutoCad is the only program open on computrer-at least that I can see on task bar.
    Any help is appreciated
    Active Member
    08-25-2009 05:29 AM in reply to: captain74
    No My problem is that I WANT to overwrite a older file and it will not let me. I can re-name the file and save it but not overwrite it. Also, at any time I can go into the OLD file and delete it- so that tells me its not locked either by someone having it open or left open in another program.
    I enclose a snap shot of desktop to better illustrate. Thank You for any Help!
    Member
    08-25-2009 06:21 AM in reply to: captain74
    I've had a similar problem. Basically not being able to over-write an existing DWF. (This may be more along the lines of the bug or the other post referenced.) I've notcied the even when I close Design Review the cache still holds onto it, I see this by looking in the task manager. If I 'end process' on the Design Review', then it will let me over write the file. Hold that helps.
    Brent
    Active Member
    08-25-2009 01:22 PM in reply to: captain74
    Thank you for the suggestion but the only program I have open is Cad 2010. ANy more suggestions?
    Employee
    08-25-2009 04:19 PM in reply to: captain74
    Do you have the DWF open in the Markup Set Manager? (MSM command)? Or by DWFATTACH?
    Or are you using Vault to store the DWG or DWF files?
    Try turning off "Publish in Background" mode and see if that helps.
    It looks like each sheet is published to an invidiual DWF file. Am I correct?
    This is a puzzling issue.
    Kevin
    Kevin Moore
    Test Development
    AutoCAD
    Autodesk, Inc.
    Active Member
    08-26-2009 06:11 AM in reply to: captain74
    Kevin, thank you for the reply. Here are the answers to your questions.
    Do you have the DWF open in the Markup Set Manager? (MSM command)? NO
    Or by DWFATTACH? NO
    Or are you using Vault to store the DWG or DWF files? NO
    NO it did not help. I still got the warning
    YES. The .dsd file consists of sheets from several separate drawing files
    Again, I am not the only one here with this issue and I can go and delete the
    original file at any time. Only when I am trying to overwrite it do I get the error.(Please see attached image in earliler post)
    I appreciate any HELP!
    Edited by: captain74 on Aug 26, 2009 1:11 PM
    Edited by: captain74 on Aug 26, 2009 1:12 PM Edited by: captain74 on Aug 26, 2009 1:13 PM
    Distinguished Contributor
    08-29-2009 04:01 PM in reply to: captain74
    I have the same problem on occasion. I open up explorer and delete the file just before you print. This is not a work around in my opionion but when you get frustrated. I find it funny that Autocad can't overwrite the file but I can delete it with my file manager. It's like Autocad seems to think the DWF is locked but no other program does.
