• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    Active Member
    Error running app with ADR2011 DWF Viewer Control in ClickOnce Deployment
    660 Views, 4 Replies
    03-03-2011 10:31 AM
    I have created a windows app using VS2008 VB.Net. This app uses the DWF Viewer control from ADR2011 (AxCExpressViewerControl). It is deployed using ClickOnce.
    This app runs fine on my developement computer, which is Win7 and has ADR2011 installed, as well as Invertor 2008 Suite.
    The problem occurs when I try to run this app on a computer with no AutoDesk apps installed.
    The clickOnce install goes fine with no errors. I can open the startup form fine. However, when I open the window that contains the DWF Viewer Control, I get this error:
    System.Runtime.InteropServices.COMException (0x80040154): Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))
    along with the full debug dump. I can supply you with the rest of the debug dump, but this might be the only relavent part:
    AxInterop.ExpressViewerDll
        Assembly Version: 1.0.0.0
        Win32 Version: 1.0.0.0
        CodeBase: file:///C:/Documents%20and%20Settings/Administrator/Local%20Settings/Apps/2.0/WV8G3C2N.V2T/Z02TQ50X.PG9/tank..tion_57812f009c7392e1_0001.0000_d09fda1857da0da5/AxInterop.ExpressViewerDll.DLL
    In the "Application Files" area of the Publish tab in VS2008, I have set AxInterop.ExpressViewerDll.dll to "Include" and "Required". I have also set the same settings for: Interop.AdCommon.dll, Interop.Commands.dll, Interop.ECompositeViewer.dll, Interop.EPlotCore.dll, Interop.EPlotModel.dll, Interop.EPlotRender.dll, Interop.EPlotViewer.dll and Interop.ExpressViewerDll.dll.
    All of the "Included" files appear to be on the test computer.
    The app is installed and run using an administrator account on an XP SP3 box.
    Am I missing something? Are there any licensing requirements involved? Is there a bootstrapper for ADR2011?
    Please use plain text.
    Employee
    Re: Error running app with ADR2011 DWF Viewer Control in ClickOnce Deployment
    03-03-2011 09:51 PM in reply to: mtwohig
    Thank you for your question.
    Your application should running with ADR installed. You can get the latest version of ADR for free from here.
    Please let me know if you have any further questions.
    Herbert He
    SW Engineer
    PSEB-GE- ACRD PSEB
    Autodesk, Inc.
    Active Member
    03-04-2011 04:31 AM in reply to: herbert.he
    Thank you for your reply.
    So, are you saying that ADR must be installed in order to use the DWF Viewer Control?
    If that is the case, is there a bootstrapper I can download?
    Employee
    03-04-2011 06:09 AM in reply to: mtwohig
    You can download the bootstrapper from http://usa.autodesk.com/design-review/
    Herbert He
    SW Engineer
    PSEB-GE- ACRD PSEB
    Autodesk, Inc.
    Distinguished Contributor
    03-09-2011 05:05 AM in reply to: mtwohig
    Be prepared for annoyed users not to bother with your application when it takes too long for the gargantuan ADR beast to load (personal experience speaking here).
    Amateur developers end up being punished for Autodesk's obstinate decision to provide a supertanker-sized viewer solution when +90% of us are crying out for a speed boat.
    KState92
    Inventor Series 2010 SR SP4
    Windows 7 64 bit - SP1
    8 GB Ram
    Quadro 2000
