• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    Member
    Design review and subparts
    492 Views, 1 Replies
    10-25-2012 04:51 AM
    When exporting from Revit we get subparts in the DWF.
    When you search for an object select it based on a property value and then issue the command Hide Others the object is also hidden. This object has a subpart, if you select the selected object and the subpart under it and use Hide Others the object is not hidden.
    My problem is that the subpart has no properties and i can not determine that the object is a subpart.
    It is not possible to see in Design Review API that the found object has a child object and that it is a subpart.
    You can not search the subpart in the Design Review Api because it has no properties, so selecting it that way is not possible.
    I am in a deadlock situation now, is there a way to select the subpart based on the entityId ? or is it possible to find out that the selected object has a subpart under it?
    regards
    Eddy Tick
    ps.
    A problem that becomes more and more anoying. Also autodesk create a .Net viewer for DWF(x) or make one that supports x64 !
    Please use plain text.
    Active Member
    Re: Design review and subparts
    10-25-2012 08:07 AM in reply to: SENL1267
    I have faced this situation before, the solution was to make an add-in to Revit that would push parametric values to nested components.
