• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    Member
    Design review 2013 will not open dwg files anymore
    1261 Views, 5 Replies
    01-23-2013 07:01 AM
    Good morning,
    2 days ago I switched to AutoCad LT from inventer (long story). It appears that design review no longer works for me as it does nothing when I try to open up DWG files. I get no error message either.
    I have updated trueview, reinstalled both deisgn review and true view to no avail.
    Are there any issues between LT and these applications I am not aware of?
    Any help would be great
    thanks in advance
    Brad
    _________________________________
    AutoCAD LT 2013
    Design Review 2013
    OS: Win 7 - 64bit
    Please use plain text.
    pendean
    Re: Design review 2013 will not open dwg files anymore
    01-23-2013 04:11 PM in reply to: brad
    ADR2013 does not open DWG files: it's a DWF viewer.
    LT, ADR and DTV (DWG Trureview) can coexist on the same PC just fine: did you completely uninstall ADT and reinstalled the combo (ADR and DTV)? recommended.
    Is LT no longer on the PC? I don't know if Inventor was an influence: what is the default DWG file application on your PC?
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Member
    02-04-2013 06:02 AM in reply to: pendean
    Previously I could open design review, select the dwg which it would them open allowing me to save a dwf file?
    How can I create a dwf file from CAD if design review does not work with dwg files no longer?
    Brad
    AutoCAD LT 2013
    Design Review 2013
    OS: Win 7 - 64bit
    pendean
    02-04-2013 10:32 AM in reply to: pendean
    You can PLOT or PUBLISH (or EXPORT in newer versions) to a DWF from AutoCAD, regardless of version.
    AutoCAD can also be set to "auto-publish" DWF files when you exit a DWG: OPTIONS command's PLOT tab controls this setting.
    Member
    03-06-2013 06:12 AM in reply to: brad
    I am still confused here.
    I was able to open design review, select a DWG file and it would open as a dwf file before, showing me all layout pages.. I assume some sort of conversion was happening on the fly. This no longer takes place. Has something changed with 2013 or am i missing something here? I have true view installed and I am running LT.
    Using the publish method does work but very slow.
    Brad
    AutoCAD LT 2013
    Design Review 2013
    OS: Win 7 - 64bit
    pendean
    03-06-2013 07:16 AM in reply to: brad
    Seems to work fine here (which is no help to you of course): I have AutoCAD 2013, LT2013, DTV2013 and ADR 2013 installed, Win7 Pro.
    Time for a reinstall perhaps?
