• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    New Member
    Design Review crashes more times a day on some pc's
    508 Views, 2 Replies
    07-24-2012 06:17 AM
    We have some pc's with windows 7 x64 on it.
    For some kind of reason design review crashes more often on those pc's, you have to think about 5 -  6 times a day. I notice that if you open some models  they use already up to 600Mb memory, after working a while with those models I have seen them using more than 2Gb of memory.
    After working a while (most with the orbit tool) the screen turns blank, and design review gets stuck, only thing you can do is end the process from the taskmanager.
    the specs of the desktop pc's are as follow:
    Dell Optiplex 990
    Intel Core i5   3.10GHz
    8 Gb memory
    Ati Radeon 5450 video card.
    We are using Design Review 2012.
    Jurgen Bruin
    System Support Engineer
    Revolving doors
    Kinderkleding online
    Please use plain text.
    New Member
    Re: Design Review crashes more times a day on some pc's
    07-25-2012 03:43 AM in reply to: Jurgen80
    Ok, I think we have found the solution by our selfs.
    It seems that not every drawing gives problems, but just a few. Also other stations had the same problems with these drawings, so the problem could not be related to the pc. It looks like the problem is in the dwf file itself. Making a new dwf file at our drawing department was the solution.
    Jurgen Bruin
    Revolving doors
    New Member
    10-05-2012 06:28 AM in reply to: Jurgen80
    My DR 2013 closes with no file open at all. Very efficient.
