• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    New Member
    Design Review and Windows 7 64-bit
    3232 Views, 18 Replies
    10-13-2009 12:53 PM
    Has anyone installed Design Review on a Windows 7 64-bit machine? I am getting an error Visual Studio 5 SP1 C++ Runtime (0x2: Failed downloading component.) Edited by: kelly3927 on Oct 13, 2009 7:59 PM
    Please use plain text.
    New Member
    Re: Design Review and Windows 7 64-bit
    10-19-2009 12:51 PM in reply to: kelly3927
    Scratch install on new HP 6930p with ATI Mobility Radeon HD3400 running x64 Windows 7, all current patches thru last Tuesday's.
    ADR 2010 dies at the splash screen when launched from the desktop, no errors, no program entry in the task list, killable process in process list only.
    When launching from Library by double-clicking on a DWF, don't even get a splash screen, no errors, no program entry, etc.
    Uninstalled and replaced with ADR 2009. Works like a champ.
    HTH
    New Member
    Oh, and that ADR 2010 was fully hotfix'ed. Made zero diff.
    Employee
    10-26-2009 08:19 PM in reply to: kelly3927
    Thank you for your report.
    Please install the Visual C++ 2005 SP1 Redistributable Package (x86) from Microsoft's website manually: http://www.microsoft.com/downloads/details.aspx?familyid=200B2FD9-AE1A-4A14-984D-389C36F85647&displa...
    Then try to install the Design Review again.
    Please let me know if you have any further questions.
    - Kenny Guo
    Kenny Guo
    SW Engineer
    Distinguished Contributor
    11-03-2009 07:15 AM in reply to: kelly3927
    I installed the C++ distributable pack (as directed) and then installed a clean version of DR 2010 and still no dice. Running Windows 7 x64 on a Dell M6400 laptop. Any other suggestions?
    -Brian Hall-
    -Brian Hall-
    Product Support
    11-04-2009 09:13 AM in reply to: kelly3927
    Are you using Equitrac?
    Shawn Niles
    Autodesk Product Support
    Shawn Niles
    Product Support Team Lead
    Product Support
    11-04-2009 10:03 AM in reply to: kelly3927
    No, not using Equitrac.
    -Brian Hall-
    New Member
    11-19-2009 07:19 PM in reply to: kelly3927
    Similar error, ADR2010, Win7 Pro-64 Bit = "The application was unable to start correctly (0xc0000142). Click to close...."
    Have applied all suggested MS & Autodesk fixes.
    Disappointing and will delay corporate deployment.
    Good advice?
    New Member
    12-14-2009 03:48 PM in reply to: kelly3927
    We also have the same problem with Design Review and Windows 7 x64 :smileysad: "...uable to start..."
    Employee
    12-14-2009 03:54 PM in reply to: kelly3927
    If you get the VC++ 2005 and VC++ 2008 redistributable packages, you use the "SP1" version. The older VC++ packages will work with the ADR installer.
    Thank you,
    Kevin
    Kevin Moore
    Test Development
    AutoCAD
