• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    Active Member
    der_roedie
    Design Review 2012 - Problem printing on A3
    585 Views, 7 Replies
    02-27-2012 07:14 AM
    one of my users has a problem with printing Design Review drawing on A3 paper format.
    When the user chooses this format, the drawing is not scaled to full page A3, it is 1/4 of the A3 paper.
    An example is added as a PDF file.
    The same drawing is printed correctly from another users PC. This leads me to believe that the problem is related to Design Review or one of its components.
    I did a complete uninstallation and reinstall of Design Review 2012 but the problem is still there. The user is able to print (and upscale) other documents to A3 from other programs (like Word and Adobe).
    Does anybody has a solution to this problem or experienced this same problem? Please let me know your steps to solve this because I am running out of ideas.
    Please use plain text.
    Employee
    Re: Design Review 2012 - Problem printing on A3
    04-05-2012 12:29 AM in reply to: der_roedie
    Thank you for reporting this issue.
    Please check "Fit to page" option in "Scaling and Alignment (2D Only)" area on Print dialog. If it still does not work, please attach a test file with detailed steps for us to reproduce this issue.
    Herbert He
    SW Engineer
    PSEB-GE- ACRD PSEB
    Active Member
    der_roedie
    04-05-2012 02:02 AM in reply to: herbert.he
    Hi Herbert,
    We tried every possible solution regarding the print settings but we never were able to fix the problem.
    I am not able to attach a file that is causing the problem because it has the .CAL extension
    How can I upload this file to you?
    Ruud
    Employee
    04-05-2012 02:26 AM in reply to: der_roedie
    Thank you for your feedback.
    Please update the file into our FTP server and let me know the file name.
      ftp://files.autodesk.com
      LoginID : simulation
      Password: ADR2009CST
    Herbert He
    SW Engineer
    PSEB-GE- ACRD PSEB
    Active Member
    der_roedie
    04-05-2012 02:30 AM in reply to: herbert.he
    Unable to logon, according FTP-log: Login Incorrect
    Please advise
    Employee
    04-05-2012 06:27 PM in reply to: der_roedie
    I'll check it. Please send the file to me directly.
    Herbert He
    SW Engineer
    PSEB-GE- ACRD PSEB
    Active Member
    der_roedie
    04-12-2012 01:04 AM in reply to: der_roedie
    Hi Herbert,
    I sent you an email.
    Hope to hear from you soon.
    Ruud
    Active Member
    der_roedie
    12-14-2012 04:39 AM in reply to: der_roedie
    Hi Herbert,
    it has been a while... did you come up with any solution?
    Kind regards,
    Ruud
