• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    Member
    DWF highlighter tool in PDF file
    1007 Views, 8 Replies
    08-28-2012 01:35 PM
    How do I get the highlighter input to show as transparent in a PDF print of the DWF file? See attachments.
    Please use plain text.
    New Member
    MikeKos
    Re: DWF highlighter tool in PDF file
    10-01-2012 01:16 PM in reply to: florencioparaon8696
    I wouldn't bother. Seriously. If you're exporting to PDF anyway, just highlight your text in Acrobat:
    http://www.ehow.com/how_7249964_highlight-text-pdf-files.html
    Just consider the user population. How many people use Autodesk, and how many use Acrobat?
    (Not to mention, there are dozens of imitators and clones of Acrobat, some of which are freeware
    or shareware, but functionally equivalent. Check out the available downloads at http://www.planetpdf.com
    and http://forums.planetpdf.com/ .)
    It's the equivalent of asking a complex technical question about the Icelandic language, when you
    could be asking how to do the same thing in English. Or Mandarin. Or French or Portugese.
    But not Icelandic, or Old Norse. (With which Icelandic shares more similarities than any of the other
    modern Scandanavian languages.)
    pendean
    10-02-2012 04:45 AM in reply to: florencioparaon8696
    As noted above, mark up PDFs directly: but you don't have to buy Acrobat, you can use freeware like FOXIT READER to do the same.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    New Member
    10-16-2012 02:47 AM in reply to: florencioparaon8696
    Is there any solution on this issue? We are also facing this problem.
    Is there any setting in ADR itself so that the highlight will remain transperent when we convert it to pdf.
    pendean
    10-16-2012 05:07 AM in reply to: mangeshsgadre
    Nope.
    Member
    10-16-2012 07:02 AM in reply to: pendean
    Thanks. I use Bluebeam Revu now. Works. A lot better than Autodesk and Adobe.
    Member
    10-16-2012 07:03 AM in reply to: mangeshsgadre
    Use Bluebeam Revu.
    pendean
    10-17-2012 06:08 AM in reply to: florencioparaon8696
    That's pretty much what all the responses here have talked about, use a PDF markup tool for PDF output files.
    Member
    11-26-2012 10:06 AM in reply to: florencioparaon8696
    I have similar problem.  I was using DWF extensively as paperless option until I started with Bluebeam.  Bluebeam has great features that outweighs DWF and Adobe Pro.  I am not sure why Autodesk cannot make DWF markups printable.
