• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    DWF Viewer Javascript API
    1126 Views, 6 Replies
    08-15-2012 01:18 AM
    There are a few examples of javascript code on the net for controlling the DWF viewer when embedded in a webapage. Is there a comprehensive guide to all available functionality.
    I am looking for a way to make the Selection be turned on by default (or a method of controlling with javascript) without having to either select the arrow from the toolbar or use the right click menu.
    Also does anyone know of a way to change the object params using javascript, I have tried modifying them with the DOM but it appears that once the dwf object is loaded the params cannot be changed without a complete page refresh.
    Any help greatly appreciated
    Paul M
    Please use plain text.
    Re: DWF Viewer Javascript API
    08-17-2012 03:24 AM in reply to: tagbagz
    Its OK I have found the solution by trial and error.
    I would like to know however if there is a way in which the current selected object in the dwf viewer can be deselected using javascript, because selecting the currently  selected object does not  cause an event to fire
    PM
    08-17-2012 08:13 AM in reply to: tagbagz
    I have managed to find a solution to the above also.
    What I would really like to know is if the properties palettes can be disabled so they do not pop up (if the user has them turned on)  when an object is clicked on.
    I have tried various permutations of:
    ADViewer.ECompositeViewer.Commands('OBJECTPROPERTIESBAND').Enabled = false;
    but this does not seem to work
    any help greatly apprecciated
    PM
    Active Contributor
    vgottipa
    08-20-2012 07:40 AM in reply to: tagbagz
    Try setting AdViewer.AutoOpenPalettesDisabled = 1
    08-20-2012 09:41 AM in reply to: vgottipa
    Many thanks that works great on the latest plug-in
    does anyone know why the design review plug-in that gets downloaded from the Autodesk Website is the 2009 version?
    is there a CAB file in existence anywhere for the 2012 or 2013 browser plug-in (the full design review download that includes the plug-in is over 700MB in size)
    regards
    Paul M
    Member
    10-15-2012 10:02 PM in reply to: tagbagz
    Can you Post the Solution, have the Same Quentin, how to change properties with the API. Thanks
    Member
    10-15-2012 10:04 PM in reply to: tagbagz
    Can you Post the Ideal, how to deselect all selected Objekts in the viewer. I can Not find any Event for that. Tanks
