• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Design Review
    Active Member
    Custom Stamp inquiry
    538 Views, 2 Replies
    03-02-2009 02:57 PM
    I'm creating a custom stamp library for our engineers and have the following questions:
    1. Is there a way to batch import stamp libraries or create multiple stamp catalogs at the same time?
    2. Is there a way to create a stamp (originally created in AutoCAD as a block) with editable text?
    3. Is there a way to reorder the stamp list in each custom catalog?
    Thank you,
    Jessie
    Please use plain text.
    *Scott Sheppard - Autodesk
    Re: Custom Stamp inquiry
    03-03-2009 10:13 AM in reply to: tealmuppet
    1. I guess you could look at the registry entries
    that are created and try to copy files around and insert those entries. This
    would be one way to batch install.
    2. The stamps are not editable text. I once tried
    to make a BAT file that created an ASCII DWF on the fly but then that old DWF
    file could not be imported as a stamp.
    3. The stamp reordering request has been around
    since the late 50's. [Yes I watch David Letterman.] The stamps get imported
    based on the order that the blocks were inserted into the DWG that produced the
    DWF. People have asked to have this be alphabetical.
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    questions: 1. Is there a way to batch import stamp libraries or create
    multiple stamp catalogs at the same time? 2. Is there a way to create a stamp
    (originally created in AutoCAD as a block) with editable text? 3. Is there a
    way to reorder the stamp list in each custom catalog? Thank you,
    Jessie
    New Member
    10-20-2012 04:54 PM in reply to: tealmuppet
    By "stamp" do you mean "symbol"?  There is no way to create a custom stamp catalog as far as I know.  If you've found a way please share it, as a lot of people have been waiting for this for a very long time.  On the other hand if you mean a symbol catalog, then it doesn't help at all.
