• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    Active Member
    Converting 3D DWG to DWF file
    495 Views, 5 Replies
    05-13-2008 01:35 AM
    Hi
    I am trying to convert a 3D dwg autocad file to 3D dwf file.but i cannot do this or by importing. i am trying to measure on 3d using DEsign Review. When choosing the paper size it does not give you the 3d option when trying to convert it
    Please use plain text.
    *V Joseph \(Beta & Customer Success Mana
    Re: Converting 3D DWG to DWF file
    05-13-2008 05:46 AM in reply to: rockm
    What version of AutoCAD are you using?
    wrote in message news:5929291@discussion.autodesk.com...
    Hi
    convert it
    Distinguished Contributor
    05-13-2008 03:27 PM in reply to: rockm
    Assuming you're using AutoCAD 2006 or newer, you can use the 3DDWFPUBLISH command from autocad to create the 3D DWF.
    John
    Active Member
    05-21-2008 07:34 AM in reply to: rockm
    I am using Autodesk design review
    Active Member
    05-21-2008 07:35 AM in reply to: rockm
    Sorry i am using Autodesk Trueview
    05-21-2008 09:08 AM in reply to: rockm
    With Trueview 2009, select 3D DWF as your Page Setup.
    The Help menu shows the step-by-step procedure for publishing 3D DWFs.
    John
