09:03 AM
- Mute
- Permalink
- Report
Hi All, I am try use your below code in JavaScript but it does't work. I am refer Autodesk Design Review 2012 API Reference I am try to Execute code in "Embedding a DWF File in a Web Page" this topic. but not able to execute, some thing is missing and i am not able to find what is missing or what is wrong. Help me. Please try to execute my Code. [code] <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html xmlns="http://www.w3.org/1999/xhtml" > <head> <script language="javascript" type="text/javascript"> function getElements() { var ADViewer = document.getElementById("ADViewer"); // 2nd Way alert(ADViewer); var ECompViewer = ADViewer.ECompositeViewer; // 1st Way alert(ECompViewer); var Sections = ECompViewer.Sections; var secList = document.getElementById("SectionList"); for (iSection = 1;(iSection <= Sections.Count); iSection++) { var Section = Sections(iSection); //Set the section to a separate object alert(Section.Title); secList.innerHTML += Section.Title + "<BR>"; } } </script> </head> <body> <input type="text" size="20" /><br /> <input type="text" size="20" /><br /><br /> <input id="abc" type="button" onClick="getElements()" value="How many input elements?" /> <object id="ADViewer" type="application/x-Autodesk-DWF" width="400" height="400" data="application/DWF085825-1-zobell_residence.dwf"> <param name="Src" value="http://50.57.86.168:8181/cat/DwfFile/DWF085825-1-zobell_residence.dwf " /> </object> </body> </html> [/code] In my PC this code execute in Google Crome but below issue. Please try this code to execute. In my Code there are 3 alert boxes. In 1 alert box shows [object HTMLObjectElement] In 2 alert box shows undefined 3 rd alert box not executed. Another thing is that this JavaScript code only run in Google Crome. not in IE 8.0 or FireFox 3.6.12 When i am using [ classid="clsid:A662DA7E-CCB7-4743-B71A-D817F6D575DF" ] this code it will not execute in Google Crome not IE 8.0 not in FireFox 3.6.12 also not loaded DWF Viewer in browser. My PC Configuration is : Windows 7 Ultimate 1 GB RAM 64-bit OS Autodesk Design Review Browser Add-on for NPAPI browser v 1.2 Autodesk Design Review 2012 Software v 12.0.0.98 installed in PC. Reply as early as possible.
Thank you.
