• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    Member
    kkcnkc
    Accepted Solution
    Can not access ADViewer object in JavaScript
    728 Views, 4 Replies
    11-17-2011 09:03 AM
    Hi All,
    I am try use your below code in JavaScript but it does't work.
    I am refer Autodesk Design Review 2012 API Reference
    I am try to Execute code in "Embedding a DWF File in a Web Page" this topic.
    but not able to
    execute, some thing is missing and i am not able to find what is missing or
    what is wrong. Help
    me.
    Please try to execute my Code.
    [code]
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
    "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
    <html xmlns="http://www.w3.org/1999/xhtml" >
    <head>
    <script language="javascript" type="text/javascript">
    function getElements()
              var ADViewer = document.getElementById("ADViewer"); // 2nd Way
            alert(ADViewer);
            var ECompViewer = ADViewer.ECompositeViewer;     // 1st Way
            alert(ECompViewer);
            var Sections = ECompViewer.Sections;
            var secList = document.getElementById("SectionList");
            for (iSection = 1;(iSection <= Sections.Count); iSection++)
                    var Section = Sections(iSection); //Set the section to a
    separate object
                    alert(Section.Title);
                    secList.innerHTML += Section.Title + "<BR>";
    </script>
    </head>
    <body>
    <input type="text" size="20" /><br />
    <input type="text" size="20" /><br /><br />
    <input id="abc" type="button" onClick="getElements()" value="How many input
    elements?" />
            <object id="ADViewer" type="application/x-Autodesk-DWF" width="400"
    height="400"
                            data="application/DWF085825-1-zobell_residence.dwf">
                    <param name="Src"
    value="http://50.57.86.168:8181/cat/DwfFile/DWF085825-1-zobell_residence.dwf
            </object>
    </body>
    </html>
    [/code]
    In my PC this code execute in Google Crome but below issue.
    Please try this code to execute.
    In my Code there are 3 alert boxes.
      In 1 alert box shows [object HTMLObjectElement]
      In 2 alert box shows undefined
      3 rd alert box not executed.
    Another thing is that this JavaScript code only run in Google Crome. not in
    IE 8.0 or FireFox  3.6.12
    When i am using [ classid="clsid:A662DA7E-CCB7-4743-B71A-D817F6D575DF" ]
    this code it will not
    execute in Google Crome not IE 8.0 not in FireFox 3.6.12 also not loaded DWF
    Viewer in browser.
    My PC Configuration is :
          Windows 7 Ultimate
          1 GB RAM
          64-bit OS
          Autodesk Design Review Browser Add-on for NPAPI browser v 1.2
          Autodesk Design Review 2012 Software v 12.0.0.98 installed in PC.
    Reply as early as possible.
    Thank you.
    Please use plain text.
    Employee
    Re: Can not access ADViewer object in JavaScript
    11-17-2011 06:17 PM in reply to: kkcnkc
    Thank you for your question.
    To insure your script works in both IE and Chrome/Firefox, please refer to this port for solution.
        http://forums.autodesk.com/t5/Autodesk-Design-Review/DWF-won-t-load-in-Firefox-nor-Chrome-but-will-i...
    Please let me know if I can be of any further assistance.
    Herbert He
    SW Engineer
    PSEB-GE- ACRD PSEB
    Autodesk, Inc.
    03-15-2012 10:51 PM in reply to: herbert.he
    I went through the links, but this only helps displaying the dwf file in mozilla/chrome, there is no way described to access the ADR control and access its controls programmatically. Please help over it.
    Thanks.
    Member
    kkcnkc
    03-16-2012 02:11 AM in reply to: usheokand
    Hi
    usheokand
    I solve my problem and also access ADViewer and with some my related funcationality.
    What you want? Please elobrate your problem. So i can help you.
    Kkcnkc
    03-16-2012 02:18 AM in reply to: kkcnkc
    Hello kkcnkc,
    thanks for replying back.
    I will explain my situation here.
    I want to display dwf files in web browser.
    So I followed the API provided for ADR and embeded the control.
    The display work is fine.
    I want to hide some of the commands, in IE am able to hide/show the command buttons over toolbar.
    But in non IE browser such as Mozilla & Chrome, I cannot access the commands.
    The IE version of accessing EComposisteViewer does not work with Mozilla.
    So I was wondering did you try to acess the command or any other child control of the ADR?
    Thanks Again.
