• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    New Member
    Re: Autodesk Design Review Embedded in HTML Page - Removing All Toolbars/Ribbon
    04-13-2012 07:29 AM in reply to: aka.kamyk
    I have a problem with a code which is working properly in Windows XP but not in Windows 7.
    The code is :
    <object id="drawing" classid="clsid:A662DA7E-CCB7-4743-B71A-D817F6D575DF" width="700" height="500">
    <param name="src" value="<%=drawing%>.dwf">
    <param name="UserMode" value="ZoomToRect">
    <param name="BackgroundColor" value="FFFFFF">
    <param name="Layout" value="TOP">
    <param name="DATAFRAMEUI" value="false">
    In Windows XP, IE 8 and Autodesk DWF viewer 7 it displays the .dwf image correctly. However, this code does not work properly in Windows 7.
    With Windows 7, IE9 and Autodesk DWF 7 viewer it shows a Autodesk box like feature . the image is present but not visible untill the canvas is dragged. Our customers are not happy with this dragging thing.
    With Windows 7, IE9 and Autodesk Design Review 2012 or 2013 edition, the image is not at all visible. All the controls are disabled.
    Please see the attached doc file for the screenshot.
    We are using Windows 7 , 64 bit.
    Please help me with this issue.
    Please use plain text.
    New Member
    04-27-2012 06:53 AM in reply to: DonaldKerr123
    I have the same problem. So far haven't solved.Part of the code below
    <script language="javascript" type="text/javascript">
      window.onload=function UserInterfaceEnabled()
       Eview.Viewer.UserInterfaceEnabled = false;  //The function did worked.
       Eview.Viewer.ToolbarVisible = false;   //The function did  worked.
       Eview.Viewer.HyperlinksEnabled = true;
       Eview.Viewer.HyperlinksSingleClickEnabled = true;   //The function didn't worked.
       //Eview.Viewer.HyperlinksHighlightingEnabled = false;
       </script>
    <object
     codebase="http://www.autodesk.com/global/dwfviewer/installer/DwfViewerSetup.cab#version=6,0,0,200"
     id="Eview"
     onLoad="load()"
    DonaldKerr123 wrote:
    I am trying to embed Autodesk Design Review in a web/html page with all toolbars and ribbons removed and am experiencing the following issues:
    1. Autodesk Design Review 2009
    I can hide everything but when the program instantiates, it creates a rectangle in the top left hand corner of the screen that covers the html underneath. Momentarily, all the toolbars appear then disappear after it loads. I've tried turning off as Params and also with Javascript to no avail. Toolbars show when the ActiveX is loading. I have tried z-index, display: none, moving off screen etc. etc. etc.
    2. Autodesk Design Review 2010
    I cannot get rid of the ribbon using Params or Javascript. Is there a Param or Javascript code to do this?
    Is there a way around any of the above two problems?
     width="100%"
     height="100%"
    <param name="src" value="../dwf/3.dwf"></param>
    </object>
    Click the HyperlinksSingleClickEnabled to the realization of the function of the no, hope everyone to think how to solve, thank you.
    Member
    10-05-2012 03:20 PM in reply to: DonaldKerr123
    hello
    my problem is the opposite. i have embeded ADR in my web and sometimes ribbon appears and sometines not when i open a dwf file. I need ribbon appears always.
    Can you help me?
    thanks in advance.
