• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    New Member
    fatlad888
    Accepted Solution
    Autodesk Design Review 2011 to PDF
    1089 Views, 2 Replies
    01-18-2011 09:43 AM
    I have a multipage DWF file which when created from AutoCAD LT 2008 retains the filename of the drawings it was published from.  These are then used as the sheet names within the new DWF file.
    If I then print from the new DWF file to PDF I would still like it to retain these sheet names within the new PDF file but it would appear that they are replaced with sheet 1, 2, 3 etc.
    Does anyone know how  to retain this information when printing from DWF to PDF?
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Autodesk Design Review 2011 to PDF
    01-18-2011 10:03 AM in reply to: fatlad888
    Which PDF driver are you using?
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    New Member
    fatlad888
    01-19-2011 01:57 AM in reply to: fatlad888
    The driver is the Adobe PDF Converter within Adobe Acrobat 8 Standard version 8.1.4
