• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    Distinguished Contributor
    Re: AutoDESK Design Review 2008 - Cant install
    03-06-2008 02:36 PM in reply to: jbryant4
    Hi all,
    By default, the command prompt in Vista does not have admin privileges enabled (which probably explains the cryptic error that a number of users are seeing when trying to manually register the vbscript.dll.) To work around this, try running the command prompt with administrator privileges by right-clicking on the Command Prompt icon (in the Start menu > Accessories folder) and choose the "Run as administrator" option. From here, manually register the dll by entering the command: regsvr32.exe c:\windows\system32\vbscript.dll.
    Best Regards,
    Scott Lillibridge, QA Manager
    Extended Design Group
    Please use plain text.
