Autodesk Design Review
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
ADR 2013 import dwg wrong page size
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Recently tried Design Review 2013 and I cannot get the page sizes to work. the same file is loaded in TrueView 2013 and the file looks great, but when I load in design review, only a portion of the file is visible. There appears to be nothing I can do about this. Please have a look at the pictures:
and the design review version of the file is here:
So you can see the letter size paper makes no sense. it is a D-size paper in true view. Model space is not much better.
Can someone help guide me to a solution?
Re: ADR 2013 import dwg wrong page size
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
TRUEVIEW is a DWG viewer.
ADR uses whatever plot parameters it finds in the layout your DWG file opens, generated a DWF, then displays it. It does not open and view a DWG file natively.
Please elaborate as ADR is not a good DWG file viewer if the DWG file is not actively set to behave as you wish it from AutoCAD.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Alright. So one has to apply the correct plot parameters within True-View and then export to DWFx. This seems to work now. Thanks! Basically I think it was a problem with the DWG file not applying any plot parameters to the layout or model space elements. Thanks for the hint and solution. I now can mark up the page with an applied plot parameter.
Carl
