• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    Member
    ADR 2013 import dwg wrong page size
    623 Views, 2 Replies
    01-10-2013 04:22 PM
    Recently tried Design Review 2013 and I cannot get the page sizes to work. the same file is loaded in TrueView 2013 and the file looks great, but when I load in design review, only a portion of the file is visible. There appears to be nothing I can do about this.  Please have a look at the pictures:
    True View 2013 drawing view. seems OK
    and the design review version of the file is here:
    Design Review version not working
    So you can see the letter size paper makes no sense. it is a D-size paper in true view. Model space is not much better.
    Can someone help guide me to a solution?
    Please use plain text.
    pendean
    Re: ADR 2013 import dwg wrong page size
    01-11-2013 05:58 AM in reply to: simpleuser1
    TRUEVIEW is a DWG viewer.
    ADR uses whatever plot parameters it finds in the layout your DWG file opens, generated a DWF, then displays it. It does not open and view a DWG file natively.
    Please elaborate as ADR is not a good DWG file viewer if the DWG file is not actively set to behave as you wish it from AutoCAD.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Member
    01-11-2013 07:55 AM in reply to: pendean
    Alright. So one has to apply the correct plot parameters within True-View and then export to DWFx. This seems to work now. Thanks!  Basically I think it was a problem with the DWG file not applying any plot parameters to the layout or model space elements. Thanks for the hint and solution. I now can mark up the page with an applied plot parameter.
    Carl
