• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    New Member
    HKItilakeskus
    Re: ADR 2012 installation issue collection
    05-05-2011 01:11 AM in reply to: LeonShi
    Downloaded the installation package and gave it a try. Good news: the installation no longer stops on the Visual Studio 2008 c++ Runtime error. Bad news: Now it stops on Visual Studio 2010 c++ Runtime internal error 0x0... (Visual Studio 2010 runtime already installed in the computer.) However, deleting the 2010 runtime component and Akamai from the computer and then running the installation again seems to fix that.
    Please use plain text.
    Employee
    LeonShi
    05-05-2011 02:27 AM in reply to: HKItilakeskus
    Hi -
    Yes, the Akamai download manager has a defect, so we need uninstall it first then relaunch ADR bootstrapper installer to refresh all cached files.
    Leon Shi
    SWD Manager
    PSEB-GE-ACRD
    MaxviewTV
    05-05-2011 03:58 AM in reply to: LeonShi
    Leon,
    Please post the link to the new downloaded. I've been having the same problem and Hasim suggested I join this forum.
    Thank you.
    Employee
    LeonShi
    05-06-2011 04:24 AM in reply to: MaxviewTV
    Hi Dear Customer -
    There is no new download link, you can still refer to ADR offical download page:
    http://usa.autodesk.com/adsk/servlet/pc/index?siteID=123112&id=12423405
    Akamai just update the online download manager, so please do uninstall "Akamai NetSession Interface" from control panel before reinstall ADR from bootstrapper.
    If you still got problem with install, please go to following page for local download installers:
    http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=10336080
    -Leon
    Employee
    05-06-2011 09:10 AM in reply to: HKItilakeskus
    If anyone still has problems installing ADR 2012, please let us know.
    Also Leon mentioned above, we believe we fully fixed the problem, but if you are still encountering a problem, we want to know so that we can fix any remaining issue.
    MaxviewTV
    05-06-2011 03:32 PM in reply to: lundbea
    I followed your directions but the problem persists!
    This is extremely frustrating.
    Any other suggestions?
    Thank you.
    Employee
    05-11-2011 02:52 AM in reply to: MaxviewTV
    Thank you for your feedback.
    Please attch the log file to this thread for investigation.
    SetupADR2012.log in the folder:
    Windows 7
    C:\Users\[your user name]\AppData\Local\Temp\AutodeskDesignReview2012Logs
    Windows XP
    C:\Documents and Settings\[your user name]\Local Settings\Temp\AutodeskDesignReview2012Logs
    And if the file vc9redist_x86.exe exist in the folder C:\Program Files\Common Files\Akamai\Cache\37309\, please install it manually, and try to run the install application again.
    Ben Wu
    SW Engineer
    PSEB-GE-ACRD
    MaxviewTV
    05-11-2011 05:58 AM in reply to: wube
    T
    Employee
    05-11-2011 04:56 PM in reply to: MaxviewTV
    Please do uninstall "Akamai NetSession Interface" from control panel before reinstall ADR from bootstrapper.
    If this doesn't work for you, could you please attach the screen shot of the folder "C:\Program Files\Common Files\Akamai\Cache\" and tell me the detail of your Operation System?
    Thank you,
    Ben Wu
    SW Engineer
    PSEB-GE-ACRD
    MaxviewTV
    05-12-2011 04:03 AM in reply to: wube
    Hi Ben,
    There is no Akamai file in my computer. I'm using a Sony Vaio vgn-fw with Windows 7 pro 64 bit.
    ADR 2010 installs and runs but not 2012. I need to view DWG files but cannot with ADR 2010.
    Thank you very much.
