• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    Member
    jonfossum
    Re: ADR 2012 installation issue collection
    04-08-2011 12:50 AM in reply to: dickyshu
    Hi
    can't install 2012 version om my computer. the default chooises are grey and i can't puch install button
    I have tryed several times with same result
    OS w7 64 bit English
    DWG TrueView 2012
    Please use plain text.
    Employee
    04-08-2011 12:57 AM in reply to: jonfossum
    Thank you for posting.
    From the snapshot you attached, we've noticed that DWG Trueview 2012 has been installed before, so that the installer blocks your attempt to install again.
    Please go to program files folder to check if that application exists.
    -Dicky
    Dicky Shu
    SQA Engineer
    PSEB-GE-ACRD PSEB
    Autodesk, Inc.
    Employee
    04-08-2011 01:34 AM in reply to: everettm
    Please make sure you get admin right to run the ADR2012 installer.
    You screen shot show that VS2010 C++ Runtime had download completed.
    Please quit the installer application and run the VS2010 C++ Runtime installer manually.
    The VS2010 C++ Runtime installer should exist in C:\Program Files\Common Files\Akamai\Cache\37309\.
    If install succeed, run the ADR2012 installer again.
    Thank you
    Ben Wu
    SW Engineer
    PSEB-GE-ACRD
    Autodesk, Inc.
    Member
    jonfossum
    04-08-2011 03:33 AM in reply to: jonfossum
    does not exist
    Member
    jonfossum
    04-08-2011 03:34 AM in reply to: dickyshu
    Trueview do exixt in the program folder
    Active Member
    everettm
    04-08-2011 07:43 AM in reply to: wube
    Yes, I have admin rights.
    I followed your instructions and installed the C++ manually with no problem.
    Then back to download and had the same stall after downloading Microsoft .NET 4.  See attached screen shot.
    Please help.
    Thanks!
    04-08-2011 10:37 AM in reply to: dickyshu
    I am having same issue.  Cannot install ADR 2012.
    OS = XP 64 bit
    Any solutions yet?
    Employee
    04-10-2011 06:56 PM in reply to: jandrews407
    Please provide more details:
    • Describe what's going on while installing
    • Capture a screenshot
    • Attach SetupADR2012.log file (C:\Documents and Settings\[your user name]\Local Settings\Temp\AutodeskDesignReview2012Logs)
    So that we can help you to diagnose the problem.
    -Dicky
    Dicky Shu
    SQA Engineer
    PSEB-GE-ACRD PSEB
    Autodesk, Inc.
    New Member
    04-10-2011 07:03 PM in reply to: jonfossum
    I've had the attached error all day.  First on my laptop which is 32bit and now on my desktop which is 64bit.  Please help.
    Employee
    04-11-2011 01:11 AM in reply to: march
    From the screenshot, I guess you've downloaded DWG Trueview 2012 standalone installer.
    ADR 2012 bootstrap installer will not show DWG Trueview 2012 install UI, maybe you can turn your question to DWG Trueview forum, there you will get answered:
    http://forums.autodesk.com/t5/DWG-TrueView/bd-p/109
    Thank you!
    -Dicky
    Dicky Shu
    SQA Engineer
    PSEB-GE-ACRD PSEB
    Autodesk, Inc.
