• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    Employee
    Re: ADR 2011 - Suggested Fixes for Installation-Related Issues
    03-02-2011 10:50 AM in reply to: djskipper
    What shortcut do you mean?
    C.
    Chris Blocher
    User Assistance Manager
    Please use plain text.
    Member
    djskipper
    03-02-2011 10:53 AM in reply to: cblocher
    You could try downloading the "bundle" from here:
    http://www.autodesk.com/designreview-download-netw​ork
    Dennis
    Employee
    03-02-2011 10:56 AM in reply to: djskipper
    Ah, thanks for the tip, Dennis. Here's the "correctly formed" link:-)
    http://www.autodesk.com/designreview-download-network
    Best,
    C.
    Chris Blocher
    03-02-2011 11:02 AM in reply to: cblocher
    Any news on yesterdays information:
    Orlando rosario
    Attached is the requested File.
    Thanks for all your help.
    Orlando Rosario
    03-02-2011 01:14 PM in reply to: cblocher
    There's a possible theory to this problem, it could very well be my logon profile to the network.
    I had the administrator log in and then installed the ADR 2011 and DWG Truview 2011, both worked like a charm.
    Thanks to All;
    Orlando Rosario
    Employee
    03-02-2011 01:20 PM in reply to: cblocher
    Hi Orlando,
    Are you all set then? Everything installed and working?
    C.
    Chris Blocher
    03-03-2011 04:52 AM in reply to: cblocher
    Everythings Up and running.
    Thanks Again;
    Orlando
    Active Member
    03-15-2011 11:34 AM in reply to: cblocher
    I've been trying unsuccessfully to install Design Review for 4 hours now.  I am attempting to run the msi on a Windows 7 Service Pack 1 (64-bit) machine.  I get this message:
    "Error 1723. There is a problem with this Windows Installer package.  A DLL required for this install to complete could not be run. Contact your support personnel or package vendor. Action _560A25DD_C4DE_4BC1_92AD_536652FFBE95, entry: Uninstall, library: C:\Program Files (x86)\Autodesk\Autodesk Design Review\UPI\UPICA.dll"
    In case you cannot see the image I tried to paste from Alt/PrtScn
    I am also attaching the msi installer log generated by this failed installation attempt.
    Help please, this is the first of 11 new workstations that need to be set up with Revit MEP.  I'd like to create an image.
    Member
    matthias.stever
    10-29-2011 07:34 AM in reply to: cblocher
    I am having the exact same problem as above. Please help!
    New Member
    nevilleparker
    Re: ADR mobile
    02-01-2012 12:07 PM in reply to: cblocher
    I've got ADR mobile on my iPad. Have loaded DWF's from revit onto the cloud. Can see the files but can't view them. Tried re- loading, tried shouting at it - all to no avail. Any advice?
