• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    Re: ADR 2011 - Suggested Fixes for Installation-Related Issues
    08-10-2010 06:43 AM in reply to: Falthor
    do not install all those windows components seprately, you'll just be spinning your wheels. Here is the easiest & most straight forward steps to install ADR 2011...read message 8
    http://forums.autodesk.com/t5/Autodesk-Design-Review/Installing-ADR-2011-in-Windows-7/td-p/2694660
    Please use plain text.
    Member
    Falthor
    08-10-2010 07:12 AM in reply to: alex_long
    actually that was not the problem either...
      Somethign had happened during the initial upgrade attempt (I was running 2010) and there were a couple of associated registry keys that were locked that I could not change or delete using ANY account on the system.
      the problem has fixed itself either way as my entire system died so I had to re-install windows and now 2011 installed without an issue.
    New Member
    Re: ADR 2011 - Suggested Fixes for Installation-Related Issues in Win 7 64-bit
    08-16-2010 01:39 PM in reply to: Falthor
    I finally got ADR to install on a clean (self installed to upgrade to 64bit) win7 ultimate machine.  I needed all of the fixes to finally get it to work.
    1. Make sure you have all the basic microsoft components.  I don't know if it is necessary, in the Control Planel on the sidebar I checked for installed microsoft components.  I had to check the Microsoft .net Framework 3.5.
    2. Ensure you also have .net Framework 4 (again do not know if this is required).
    3. Ensure you have the required Visual  C+++ Redistributable packages installed (2005 and 2008)
    4. I downloaded and ultimately installed using the .msi package
    5. All future commands were run as administrator
    6. Registered the VBScript and JScript engines.  Start - All Programs - Accessories - CMD Prompt - Runa as Administrator.  This should get you a command prompt in the Windows\System32\ dir.
    7. Register the VBScript.  At the cmd line type regsvr32 vbscript.dll and press enter.  You should get a message box that says registration successfull.
    8. The failures are generally windows failures.  When I used the .exe file from Autodesk I got a 0x643 internal error.  Some searching on that in combination with the VB error 2738 also pointed to additional registry issues.  The fix is to make sure everything is registered under HKEY_LOCAL_MACHINE and not HKEY_CURRENT_USER.
    9. You can remove the keys at HKCU either by directly editing your registry - be careful these are long strings and many look alike - you can seriously bork your install or by running the following commands at the command prompt using the Run as Administrator (right click) option.  I've included the commands for both 32bit and 64bit installs.
    Click on the Start menu, choose Run, type cmd and click OK
    32 bit System:
     To unregister the VBScript engine, run this command:
              reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f
      To unregister the JScript engine, run this command:
               reg delete "HKCU\SOFTWARE\Classes\CLSID\{F414C260-6AC0-11CF-B6D1-00AA00BBBB58}" /f
    64 bit System
      To unregister the VBScript engine on a 64-bit OS, run this command:
               reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f
      To unregister the JScript engine on a 64-bit OS, run this command:
               reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{F414C260-6AC0-11CF-B6D1-00AA00BBBB58}" /f
    I did this in this order and then checked my registry.  The CLSID were in there proper location under HKLM (Dont't know if they were always there or ended up there when I registered VBScript.dll.  I then ran the .msi file as an adminstrator and had not problems.
    Since this is a new install, I don't know if all of this will cause problems with permissions later on as different users have to use the machine, but at least it is installed - for the moment.
    I realize these are MS errors and issues, but I would appreciate a more thorough answer from AD support.  It's taken me half a day to figure this out and it's not my job.  Surely with AD resources, they could have pieced this thing together as well.
    08-17-2010 06:08 AM in reply to: ddcarter
    WOW that is ridiculous!!
    Average Joe computer user would read that and their brain would explode. They / We should be able to click on the link to DL the software from the website and it install correctly the 1st time, period. I would never take that amount of time performing surgery to get a piece of software to install.
    Autodesk needs to step it up!!
    New Member
    08-17-2010 07:58 AM in reply to: alex_long
    @Alex_Long
    My point exactly.  I do not have the problems with installation, activation, system fouling issues with any other software.  While researching (googling) the problem I ran across many warnings about msi and installer programming errors that can have unintended behaviour at the least and at worse, wreck havoc with a system.  This is an installer issue and should have been fixed by Autodesk.
    Check for components, ask to install, check for known inhibitors and tell the user how to fix the problem.  The open source community gets this, why doesn't Autodesk?
    Although I have the software installed, I am not convinced it hasn't broken something else.  Each support issue I have had, I have been asked to provide feedback and assured that the developers listen.  I have yet to see evidence of it.
    Sorry for the rant but my frustration is with Autodesk, and it is a lot of money to pay to be this mad.
    Autodesk are you listening?
    Employee
    08-30-2010 08:04 PM in reply to: ddcarter
    The Design Review team does appreciate and encourage your feedback on this discussion board. We bring your concerns and ideas to the attention of the entire Design Review team to be discussed. The result of these internal conversations can often be seen in the many responses made by Autodesk employees. We're doing everything we can, publicly and behind the scenes, to improve your experience with Design Review.
    Although these discussion boards are intended for peer-to-peer support, it's clear that customer expectations extend beyond that. In fact, because of discussion board responses pertaining to previous releases, we created this particular thread to encourage this kind of installation conversation. We want to investigate new issues, as well as help, when possible, resolve installation issues being posted.
    Do we always have the answers? No. Are we listening? Definitely! Together we can find resolutions and improve the product at the same time.
    Sincerely,
    Chris
    Chris Blocher
    User Assistance Manager
    New Member
    10-13-2010 08:08 PM in reply to: cblocher
    Thanks very much for this post. It was the longest install I ever had. I went thru every step until I was able to install. It looks like we need better uninstall autodesk software programs for many items stay behind with the typical control panel/uninstall program rutine. Againg thanks for the words of wisdom..... keep it up!
    I am very impressed with the  design review software...
    Member
    AutojetTechnologies
    Autodesk Design Review 2011
    01-04-2011 08:09 AM in reply to: cblocher
    I have a problem of instalation with the software Autodesk Design Review on 2011.
    An error arose " error 1904 " the module: c:\Program Files\Fichiers communs\Adview.dll was not able to be to register(record). HRESULT-2147220473
    Boubaker NOURI
    Technicien d'atelier- Soudeur
    Workshop- Technician
    Route Blanche, Quartier St. Pierre-13120-Gardanne-FRANCE
    Tel: +33 (0)4 42 50 92 82
    Fax: +33 (0)4 42 50 92 90
    Email:nouri.b@spray.com
    www.spray.com, www.autojet.com.
    Boubaker NOURI
    Boubaker NOURI
    AutoJet Technologies
    a division of Spraying Systems Co.
    Experts in Spray Technology
    Rte Blanche, Quartier St. Pierre-13120-Gardanne-FRANCE
    Tel: +33 (0)4 42 50 92 81
    Direct : +33(0)4 42 50 92 82
    Employee
    Re: Autodesk Design Review 2011
    01-04-2011 08:25 AM in reply to: AutojetTechnologies
    See if either of these posts help:
    If not, can you please provide some more information?
    • What other Autodesk products/versions are installed on the system(s) that may be associated with the issue?
    • What are the specifics of the computer you're trying to install on (hardware brand, operating system/processor [32- or 64-bit], RAM, video card, connections [local and network], etc.)?
    • What type of installation (single computer or network deployment).
    • Where did you get Design Review (Autodesk.com or the media of another Autodesk product)?
    Chris
    Chris Blocher
    Member
    AutojetTechnologies
    01-18-2011 11:55 PM in reply to: cblocher
    First of all saddened for my approximate English, I have a problem in the execution Design Autodesk Review I do not manage to open the program. I tried of the repair and two errors arose:
    -Erreur 1904. Le module c:\Program Files\Fichiers communs\Autodesk Shared\DWF common\AdView.DLL n'a pu    s'enregister HRESULT-2147220473.
    -Erreur 1904. Le module c:\Program Files\Autodesk Design Review\Ecomposite\DWFxImporter.DLL n'a pu s'enregister HRESULT-2147220473.
    Can you help me?
    Boubaker NOURI
