• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    Valued Contributor
    ADR 2011 Font not coming in correctly
    1379 Views, 8 Replies
    06-08-2010 11:57 AM
    Once I upgraded to ADR 2011, some of the fonts are not coming in correctly when we look at a dwf file.  In our office some computers still had version 2010 and the files look fine on there, but for some reason version 2011 doesn't recognize them.  Some of the letters look OK but others are replaced with a rectangle box.
    I've checked other computers using 2011 and they all show the font as being messed up so it's not just my computer, but older versions of ADR work fine.  Does anyone have a remedy for this or experienced this yet?  Im trying to avoid uninstalling 2011 to replace it with an older version.
    Thanks for the help.
    Please use plain text.
    Employee
    Re: ADR 2011 Font not coming in correctly
    06-08-2010 10:29 PM in reply to: dficarra
    Thank you for the reporting.
    I did not experience this issue.
    Could you please attach your DWF file for further investigation?
    -Sting
    ADR/DWF Customer Support
    -Sting
    SQA Engineer
    PSEB-GE-ACRD PSEB
    Autodesk, Inc.
    Valued Contributor
    06-09-2010 08:03 AM in reply to: dficarra
    Sure, here you go.
    Employee
    06-09-2010 08:07 PM in reply to: dficarra
    Thank you for your file.
    I reproduced this issue in ADR 2011. The numeric letters are replaced with the rectangles.
    I have logged a bug to the Bug Tracking System.
    If you want to avoid this issue at once, please change your system language to a double-byte language such as Chinese or Japanese, because those numeric letters look like double-byte. Yes, I changed the language and then it displayed correctly.
    For XP system:
    1. Go to Control panel.
    2. Open the Regional and Language Options dialog.
    3. Click Advanced tab.
    4. Expand the drop-down list at the Language for non-Unicode programs field.
    5. Choose Chinese (PRC).
    6. Click Apply.
    7. Click Yes to restart the system.
    Please let me know if I can be of any further help.
    -Sting
    -Sting
    SQA Engineer
    PSEB-GE-ACRD PSEB
    Autodesk, Inc.
    Valued Contributor
    06-10-2010 08:18 AM in reply to: Liust
    I don't have Chinese or Japanese as an option in that drop down.  And it seems pretty rediculous that in order to get this to work I have to set my computer to a language I don't even speak.  What causes this problem from Autodesk and why haven't they developed a patch to fix this?
    Seems like every time we do a so-called "up grade" to anything from Autodesk it works worse than the previous version we had.  That goes for Auto CAD as well.
    I have uninstalled the ADR 2011 and will now be attempting to find version 2010 to download back to my computer and WILL NOT be upgrading it.
    If you know of another way please let me know, but I'm really tired of their programs causing delays and eatting up our time in the office because they can't produce a stable, quality product that performs the way it should!
    Distinguished Contributor
    06-11-2010 10:16 AM in reply to: Liust
    Sting, I am having the same issue, when can we expect a patch?
    Employee
    06-11-2010 06:15 PM in reply to: WStu
    Thank you for your feedback.
    This issue has been logged to the Bug Tracking System.
    -Sting
    SQA Engineer
    PSEB-GE-ACRD PSEB
    Autodesk, Inc.
    Employee
    10-01-2010 06:29 AM in reply to: dficarra
    I've duplicated this issue as well.
    OS: Windows XP
    Srv Pack 3
    Pentium 4 @ 2.80 ghz
    RAM: 1.99 GB
    IE: 8.0.6001.18702
    Autodesk Design Review 2011  11.0.1.86
    I view DWF file in ADR 2011 fonts do not display
    I view DWF file in ADR 2010 fonts appear correctly
    In ADR 2011 I resave file as DWFx and fonts appear correctly
    Employee
    03-23-2011 11:44 PM in reply to: james.l.bryant
    This defect should be fixed in ADR 2012. You can download ADR 2012 for free from here.
    Thank you for supporting Autodesk Design Review.
    Herbert He
    SW Engineer
    PSEB-GE- ACRD PSEB
    Autodesk, Inc.
