• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Design Review
    *David Metcalf
    ABS 2005 DWF into Arch Studio
    86 Views, 2 Replies
    06-21-2004 04:02 PM
    I plotted a couple mass objects to DWF from ABS 2005 with the stock DWF6 eplot.pc3 setup and get errors when inserting the DWF into AAS 3.0. It comes back with unable to read file.
    Please use plain text.
    Valued Contributor
    Re: ABS 2005 DWF into Arch Studio
    06-21-2004 06:26 PM in reply to: *David Metcalf
    Hi David,
    This is interesting. Could you attach a sample of your file? I'll pass it along and see what we can figure out. You are using Arch Studio 3.0 and not 3.1? The correct version number should appear in the Help, About Arch Studio pull down menu.
    Thanks for posting.
    --Doug
    *David Metcalf
    06-22-2004 10:31 AM in reply to: *David Metcalf
    Good Morning Doug, I am getting calls from users who have taken Version 3.0.1750, which are the sample CDs we provide to propsective buyers. Would that be the reason? Can I download and burn to CD the lastest for trail versions? If not, I can send you the file. But I tested on 3.0 with a real simple MAP 3D 2005 and ABS 2005 dwg file to dwf. David "Doug Look, Autodesk" wrote in message news:7404367.1087867646855.JavaMail.jive@jiveforum2.autodesk.com... > Hi David, > > This is interesting. Could you attach a sample of your file? I'll pass it along and see what we can figure out. You are using Arch Studio 3.0 and not 3.1? The correct version number should appear in the Help, About Arch Studio pull down menu. > > Thanks for posting. > > --Doug
