• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk DWF Viewer
    Valued Contributor
    W98 PROBLEM FIXED?
    94 Views, 9 Replies
    05-12-2003 07:34 PM
    Does anyone know if the EV W98 problem has been fixed and posted? If not, Autodesk, any iedas on time?
    Thanks.
    Please use plain text.
    *Autodesk\
    Re: W98 PROBLEM FIXED?
    05-12-2003 11:09 PM in reply to: joneschester
    There may have been several Win98 problems fixed in
    the upcoming service pack.  Which one, in particular, were you referring
    to?
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    Does
    any iedas on time?
    Thanks.
    Valued Contributor
    Re:
    05-13-2003 10:35 PM in reply to: joneschester
    This one:
    Can someone confirm the following: Have EV already installed. Go to: http://usa.autodesk.com/adsk/servlet/item?id=3023925&siteID=123112 More the slider bar up and down. Do you get strange results in the top left of the screen?
    *Autodesk\
    Re:
    05-13-2003 11:30 PM in reply to: joneschester
    Ah yes, I believe we have fixed that one in the
    service pack that's due out very soon.
    This
    one:
    href="http://usa.autodesk.com/adsk/servlet/item?id=3023925&siteID=123112">http://usa.autodesk.com...
    the screen?
    *Lipman, Jos Groot
    Re:
    05-13-2003 11:53 PM in reply to: joneschester
    Will that service pack be something to apply to an
    existing installation (a separate download)
    or is
    the cabinet file at
    going to be updated to a newer version so that
    upgrading of existing installations will be automatically?
    Jos Groot Lipman
    "Jeffrey Klug (Autodesk)" <jeffrey dot klug at autodesk dot com>
    wrote in message
    href="news:6177606155CC63684BE318C59E79CF8A@in.WebX.maYIadrTaRb">news:6177606155CC63684BE318C59E7...
    This
    one:
    href="http://usa.autodesk.com/adsk/servlet/item?id=3023925&siteID=123112">http://usa.autodesk.c...
    of the screen?
    *Autodesk\
    Re:
    05-14-2003 12:06 AM in reply to: joneschester
    The CAB file will be updated.
    an existing installation (a separate download)
    size=2>or is the cabinet file at
    Jos Groot Lipman
    wrote in message
    href="news:6177606155CC63684BE318C59E79CF8A@in.WebX.maYIadrTaRb">news:6177606155CC63684BE318C59...
    This
    one:
    href="http://usa.autodesk.com/adsk/servlet/item?id=3023925&siteID=123112">http://usa.autodesk...
    left of the screen?
    *Sheppard, Scott
    Re:
    05-14-2003 03:19 AM in reply to: joneschester
    After Autodesk updates the CAB file, if you have
    HTML pages that look like:
    OBJECT
    id=Eview
    size=2>codeBase=http://www.autodesk.com/global/expressviewer/installer/ExpressViewerSetup.cab#version=3,1,0,78
    classid=clsid:A662DA7E-CCB7-4743-B71A-D817F6D575DF
    width=470
    height=355
    users who view your pages will not automatically
    get an updated copy if they already have the current version. Of course users
    who have nothing will get the updated one, since the new CAB file will download
    and install. (I have removed the angle brackets from the tags so as not to
    confuse the newsreader software.)
    If you want to fix this, you will have to update
    your pages to reflect the new version. Let's say the next update is 3.2 build
    93. Then you would update your page to be:
    OBJECT
    id=Eview
    size=2>codeBase=http://www.autodesk.com/global/expressviewer/installer/ExpressViewerSetup.cab#version=3,2,0,93
    width=470
    height=355
    This means that your page requires version 3.2.0.93. If a user already had
    3.1.0.78, this does not meet the requirement, so the CAB file would download and
    install. This would upgrade the user from 3.1.0.78 to 3.2.0.93. Recall that
    3.2.0.93 is just an example. The next release of AEV may be something like
    3.1.0.86 -- I don't know what it will be -- but it will be at least
    3.1.0.79.
    wrote in message
    href="news:smileyvery-happy:5575ECD54CBE06357D4F96114A9E2E7@in.WebX.maYIadrTaRb">news:smileyvery-happy:5575ECD54CBE06357D4F96114A9E2E...
    Jos Groot Lipman
    com> wrote in message
    href="news:6177606155CC63684BE318C59E79CF8A@in.WebX.maYIadrTaRb">news:6177606155CC63684BE318C...
    the service pack that's due out very soon.
    This
    one:
    href="http://usa.autodesk.com/adsk/servlet/item?id=3023925&siteID=123112">http://usa.autode...
    left of the
    screen?
    Active Contributor
    Re:
    06-13-2003 02:57 AM in reply to: joneschester
    The service pack appears to have initially fixed this problem, BUT after you print a file the display problem mentioned above comes right back. The problem still only appears to be related to WIN98. We have tried it on several different WIN98 machines and they all have the same problem. Is anybody else experiencing this problem?
    New Member
    Re:
    06-15-2003 08:02 PM in reply to: joneschester
    Mark,
    I am experiencing the same problem - try to print, then the DWF appears at the top left of the screen.
    Win98, Express version 3.1.0.92
    *Rui
    Re:
    06-15-2003 10:54 PM in reply to: joneschester
    Hi there!
    I also have the same problem with WinME. When I click the Print button and
    then Cancel, the image "runs" to the top left corner of the screen.
    Rui
