• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk DWF Viewer
    Member
    Viewer won't run
    436 Views, 5 Replies
    01-08-2010 03:11 AM
    instalation succesfull
    but when launching splash screen appears then quickly disapears and nothing hapends afterwards
    it apears with trueview2009, trueview2010, designreview2009, designreview2010, mechanical 2008, acad2008
    Please use plain text.
    *Dean Saadallah
    Re: Viewer won't run
    01-09-2010 06:24 AM in reply to: sandmanpl
    So you installed 6-apps and none work?
    Or you changed PCs or OS and these all died?
    Dean Saadallah
    http://LTisACAD.blogspot.com
    Member
    01-10-2010 11:43 PM in reply to: sandmanpl
    same PC same OS all six apps act the same way
    *Dean Saadallah
    01-11-2010 04:29 PM in reply to: sandmanpl
    new installs? all of them?
    Dean Saadallah
    Member
    01-12-2010 01:13 AM in reply to: sandmanpl
    there was acad2004 insalled but i needed to open drawings in 2009 format
    so i installed trueview2009 it didn't run
    so i installed trueview2010 it didn't run also then i uninstalled the acad2004 but it didn't help
    them i installed the designreview and then the mechanical2008 and none of them opens
    *Dean Saadallah
    01-12-2010 05:10 AM in reply to: sandmanpl
    WinXP or Vista?
    Does the PC system meet the SSE2 requirement?
    .NET Framework 3.5 sp1 installed?
    is DEP in Windows holding off the launching of the apps?
    Are you logged in as full administrator?
    Does R2004 still work?
    DTV2010 have a patch for a similar symptom, did you try that?
    The fact that 5apps do not run is an indication of a Windows or system choke
    point... .
    Dean Saadallah
