• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk DWF Viewer
    Active Contributor
    Publishing View Problems
    241 Views, 1 Replies
    03-23-2010 08:22 AM
    I use a .dsd publish file to publish multiple maps nightly between midnight and 3 am. I am using AutoCAD Map 2010 and it seems to be saving my .dwf files at different zoom levels. I run it with my old software 2008 and it works perfectly. What it does is on some of the .dwf maps it zooms to a specific location instead of showing the entire .dwf on start up. Doesn't seem to be a problem with 2008 and works fine. Anyone seeing these same issue's with 2010?
    Thanks for your time.
    Chad Kersten
    SRT Communications, Inc
    Minot, ND
    701-838-9835 Edited by: chadlk@srttel.com on Mar 24, 2010 8:21 AM
    Please use plain text.
    Employee
    Re: Publishing View Problems
    03-29-2010 07:07 PM in reply to: chadlk
    Thank you for your question.
    This question is about AutoCAD publishing and one other discussion group focuses specifically on this issue.
    Please try the following link for your convenience.
    AutoCAD Map 3D
    Please let me know if you have any further question.
    -Doris Song
