• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk DWF Viewer
    Member
    Fatal Error: Unhandled Access Violation Reading 0x0da4 Exception at 36007973h
    309 Views, 4 Replies
    11-01-2004 08:03 AM
    Does anyone know of a fix for this error when trying to view CAD drawings with the DWF Viewer? The drawing opens for a matter of seconds then closes with this error message which isn't a lot of help.
    Please use plain text.
    *John Schmier - Autodesk
    Re: Fatal Error: Unhandled Access Violation Reading 0x0da4 Exception at 36007973h
    11-01-2004 09:50 AM in reply to: olnitch
    If possible, can you please post the file? Also, what version of DWF Viewer are you using?
    Member
    11-02-2004 08:07 AM in reply to: olnitch
    Just realised that its actually Autodesk DWG viewer. Build version 1.0.0.116
    Can't see a discussion group for DWG viewer, but if you can help with this, that would be great
    11-02-2004 10:36 AM in reply to: olnitch
    Try posting to autodesk.dwf.composer I would recommend posting the dwg (and supporting files) if possible.
    New Member
    04-28-2010 12:48 PM in reply to: olnitch
    I got this error message( !laymgr.cpp@987:elockviolation) today after launching & opening file previously saved in AutoCade 2007 LT. I had work on Autocad three day ago and I did not encounter such problem. I remember that since then, I have installed software Defender Pro 2010 (DP). Therefore after a Uninstalling & reinstalling the AutoCad the problem was not solved. I decided to uninstall DP from my system. After rebooting my system, I launching Autocad, the error was gone and the program appeared to be working flawlessly. Problem is DP not AutoCad.
    Conclusion: If anyone getting the above error, uninstall your Anti-Virus particularly DP 2010. DP has some thing to do with it.
    I hope this resolve your issue.
