• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk DWF Viewer
    Member
    MikhailRogachev
    Error message opening DWFx files
    2166 Views, 4 Replies
    09-29-2010 12:50 PM
    I have made website and use control:
    object id="ADViewer" classid="clsid:A662DA7E-CCB7-4743-B71A-D817F6D575DF"
        width="800" height="640" VIEWASTEXT
        param id="dwfvalue" name="Src" runat="server" value=""
    object
    It's working with DWF files very well. Thanks
    However when I tried to open *.DWFX file I have got message then this file's type doesn't support.
    The wheels product given me same error.
    Could you give me any help?
    Mikhail
    Please use plain text.
    Employee
    Re: Error message opening DWFx files
    09-29-2010 11:03 PM in reply to: MikhailRogachev
    Thank you for your question.
    If *.DWFx files also cannot being opened by Autodesk Design Review (ADR) directly. Please uninstall and reinstall ADR from here.
    Please let me know if I can be of any further assistance.
    Herbert He
    SW Engineer
    PSEB-GE- ACRD PSEB
    Autodesk, Inc.
    Member
    MikhailRogachev
    09-30-2010 12:06 PM in reply to: MikhailRogachev
    Hello herbert.he,
    Thanks for your message.
    Today I have found one more reason. I have created two similar html-pages and put their on two different websites. One page is working very well, second one is not working. I don't know kind of first server, but know second one - IIS7.
    Do you know what I have to change on IIS7?
    This example is working
    This example has the error message
    Mikhail
    Employee
    10-07-2010 10:46 PM in reply to: MikhailRogachev
    Thank you for your feedback.
    Both of your examples are working on my side, see the attached snapshots.
    And I noticed that there are some script code differences between your two examples. Please edit the example which has the error message accordingly, and then try again.
    Any further questions please let me know.
    Herbert He
    SW Engineer
    PSEB-GE- ACRD PSEB
    Autodesk, Inc.
    Member
    MikhailRogachev
    10-08-2010 12:10 AM in reply to: MikhailRogachev
    Thank for the answer. You right - now it is working. It was some issue on the server.
    Mikhail
