• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk DWF Viewer
    New Member
    hamilton318
    Error When Opening DWF File
    517 Views, 1 Replies
    06-22-2010 10:31 AM
    Using
    Autodesk Design Review version 11.0.0.86
    Windows XP Pro SP3
    Intel Core 2 Duo 2.53 GHz
    3 Gb Ram
    When trying to open a .dwf file, I get the error : Your current version of Design Review does not support files of this type.
    Any ideas?
    Please use plain text.
    pendean
    Re: Error When Opening DWF File
    06-22-2010 05:40 PM in reply to: hamilton318
    Your DWF is either corrupt, or you need to rename it from FILENAME.DWF to FILENAME.dwf (not caps for extension). Helps if you have Windows Explorer set to show file extensions, otherwise you will not be able to change it where it matters.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
