Autodesk DWF Viewer
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
DWF Viewer ActiveX Design Idea
- Highlight
- Email to a Friend
All,
I wanted to run this by before I beat myself up trying to do it. I will be viewing single page .dwfs. On the OnEndLoadItem event I would like to remove all markup objects that may be on the dwf, and then using Content3 and Object3 Move through all of the objects on the dwf and programmatically draw markup objects using the extents I can get from Object3.
Is this possible? Or a resonable approach? This will provide some visual feed back on load for me.
Let me know if this sounds ok.
Thanks.
Re: DWF Viewer ActiveX Design Idea
- Highlight
- Email to a Friend
My Logical Flow would be like this.
Set ObjectContent to Section.Content as IAdContent3
If ObjectContent HasMarkups
Make Sure All Markup objects are not locked.
Then Delete All Markups
For each object in the section
Get the object extents
Get the object properties 'For my use in the application
Look Up some values in a database using the object properties
Create a markup object the size of the object extents and fill a cetain color basked on the lookup values.
I hope this helps... Let me know if this is possible.
Thanks in advance.
- Highlight
- Email to a Friend
In the step "Make Sure All Markup objects are not locked" Where is this setting.
In looking in the API documentation I do not see that as a property of a markup object.
I only see .Status and .Note and under enum Status, there is nothing for locked.
The code :
Set CompositeViewer = CExpressViewerControl1.ECompositeViewer
Set Section = CompositeViewer.Section
Set ObjectContent = Section.Content
Set MyObjects = ObjectContent.Objects(2)
If ObjectContent.HasMarkups Then
ObjectContent.DeleteMarkups MyObjects
End If
Works fine as long as the Markup Objects are not locked. How can I set them to unlocked?
- Highlight
- Email to a Friend
Thank you for your question.
Autodesk Design Review currently does not support to unlock markup(s) via API.
I've added your requirement to our WISHLIST database. We will consider it for possible inclusion in future releases.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
- Highlight
- Email to a Friend
Is there a way to create Markup Objects via the API?
like to get the extents of an object and then create a markup object using that iadRect and fille with a green highlighter or something along those lines?
- Highlight
- Email to a Friend
No, we don't have any API for creating markups.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
