• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk DWF Viewer
    Active Member
    vtkegan
    DWF Viewer ActiveX Design Idea
    2756 Views, 5 Replies
    12-16-2010 05:32 AM
    All,
    I wanted to run this by before I beat myself up trying to do it. I will be viewing single page .dwfs.  On the OnEndLoadItem event I would like to remove all markup objects that may be on the dwf, and then using Content3 and Object3 Move through all of the objects on the dwf and programmatically draw markup objects using the extents I can get from Object3.
    Is this possible?  Or a resonable approach?  This will provide some visual feed back on load for me.
    Let me know if this sounds ok.
    Thanks.
    Please use plain text.
    Active Member
    vtkegan
    Re: DWF Viewer ActiveX Design Idea
    12-16-2010 06:14 AM in reply to: vtkegan
    My Logical Flow would be like this.
    Set ObjectContent to Section.Content as IAdContent3
    If ObjectContent HasMarkups
    Make Sure All Markup objects are not locked.
    Then Delete All Markups
    For each object in the section
    Get the object extents
    Get the object properties 'For my use in the application
    Look Up some values in a database using the object properties
    Create a markup object the size of the object extents and fill a cetain color basked on the lookup values.
    I hope this helps... Let me know if this is possible.
    Thanks in advance.
    Active Member
    vtkegan
    12-16-2010 07:12 AM in reply to: vtkegan
    In the step "Make Sure All Markup objects are not locked"  Where is this setting.
    In looking in the API documentation I do not see that as a property of a markup object.
    I only see .Status and .Note and under enum Status, there is nothing for locked.
    The code :
        Set CompositeViewer = CExpressViewerControl1.ECompositeViewer
        Set Section = CompositeViewer.Section
        Set ObjectContent = Section.Content
        Set MyObjects = ObjectContent.Objects(2)
        If ObjectContent.HasMarkups Then
            ObjectContent.DeleteMarkups MyObjects
        End If
    Works fine as long as the Markup Objects are not locked.  How can I set them to unlocked?
    Employee
    12-16-2010 08:20 PM in reply to: vtkegan
    Thank you for your question.
    Autodesk Design Review currently does not support to unlock markup(s) via API.
    I've added your requirement to our WISHLIST database. We will consider it for possible inclusion in future releases.
    Herbert He
    SW Engineer
    PSEB-GE- ACRD PSEB
    Autodesk, Inc.
    Active Member
    vtkegan
    12-17-2010 08:12 AM in reply to: herbert.he
    Is there a way to create Markup Objects via the API?
    like to get the extents of an object and then create a markup object using that iadRect and fille with a green highlighter or something along those lines?
    Employee
    12-19-2010 06:41 PM in reply to: vtkegan
    No, we don't have any API for creating markups.
    Herbert He
    SW Engineer
    PSEB-GE- ACRD PSEB
    Autodesk, Inc.
