• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk DWF Viewer
    New Member
    praneeta24
    DWF File format setting up
    669 Views, 1 Replies
    07-14-2010 02:29 AM
    This is Praneeta and I have one query regarding DWF File format setting.
    Currently our application creates DWF files of American standard format ANSI 8.5*11. we want to convert the DWF file format to ISO A3 format.
    Manually we can do this by setting up ISO format using DWF writer for 2d or 3d.
    Can it be feasible, that we can use DWF writer properties which can set the DWF file format through any code or so and it will create DWF files of ISO format?
    Please help me....
    Thank you in advance.
    Praneeta
    Please use plain text.
    Employee
    Re: DWF File format setting up
    07-15-2010 06:53 PM in reply to: praneeta24
    Hi Praneeta,
    Thank you for posting.
    I am afraid there is no API control of the DWF Writer Properties – and adding that at this time is not in scope, so you may not be able to do that from code.
    Hope it answers your question.
    -Dicky
    Dicky Shu
    SQA Engineer
    DWF Writer Customer Support
    Dicky Shu
    SQA Engineer
    PSEB-GE-ACRD PSEB
