• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk DWF Viewer
    New Member
    Autodesk Design Review Error
    307 Views, 1 Replies
    11-20-2009 05:08 AM
    For the last 3 days I have received an error message everytime I try to view a document.
    It states that a software problem has caused Autodesk to close unexpectedly.
    The report content is as follows:
    Design Review.10.0.0.108_2009_11_20_08_04_36_0968_2f.dmp
    dmpuserinfo.xml
    dumpdata.zip
    I have tried removing the program and re-installing it and I get the same results.
    Can you give me any help or is this an issue on your end.
    Please use plain text.
    Employee
    Re: Autodesk Design Review Error
    11-24-2009 07:39 PM in reply to: scot522
    Thank you for submitting the CER report for this problem.
    Please post back to this thread the email address you used when submitting the CER (and a description of the steps to reproduce the problem) so that I can find your CER and then investigate this problem further.
    If you didn't submit an email address with the CER, then please resend the report with an email address and post the information back to this thread as requested above.
    Dony
