• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk DWF Viewer
    Any way to convert downloaded .pdf files to dwg or dwf' with the Desgn Rev?
    261 Views, 3 Replies
    01-05-2010 10:16 AM
    Hi, I have a friend who receives plans from designers via downloaded .pdf's.
    Is there a way he could convert them for use by the Design Reviewer?
    Thanks!
    Kip
    Please use plain text.
    Member
    Re: Any way to convert downloaded .pdf files to dwg or dwf' with the Desgn
    01-06-2010 01:33 AM in reply to: wingnut77
    Convert to DWF - not a method
    Convert to DWG - and you do not need to convert with the Desigh Rev. Edited by: Discussion_Admin on Jan 6, 2010 11:08 AM
    01-06-2010 04:05 AM in reply to: wingnut77
    Perfect, Judy! Thanks! Kip
    *R.K. McSwain
    Re: Any way to convert downloaded .pdf files to dwg or dwf' with the Desgn Rev?
    01-06-2010 05:39 AM in reply to: wingnut77
    > downloaded .pdf's.
    You don't need to "convert" anything, because Design Review will open
    PDF files.
    If you want, you can save the PDF to DWF after you open it.
    R.K. McSwain
    http://cadpanacea.com
